Results 1 to 16 of 16
How do you get out a snapped bolt ?
    Posting Freak danny86's Avatar
    MA/NH
    I apparently tightened a bolt that held in the oil filter too tightly on my dirtbike and it snapped in half, how do I get it out?
    Thanks.
    Lifer Danz19899's Avatar
    Grafton, Ma
    Re: How do you get out a snapped bolt ?
    Blood, sweat, tears lol
    on a more serious note easy outs work well. its basically a drill bit but with a left hand angle claw at the end that grabs and pulls out the rest of the bolt
    but sometimes that dont work and u might need to drill and tap the bitch
    www.bostonmoto.com
    Ride to live, live to ride
    MA/NH
    This sucker is buried deep, do you still recommend an EZ out? This is something I can't afford to screw up as its attached to the motor and stripped the threads on this will really fck my life up, might just give it to the mechanic down the street and give him like $0 to take it out
    Grafton, Ma
    if you have somewhere that will do it for cheap go for it, sometimes it can be easy but sometimes it can be a real Bitch lol either way they have to deal with it
    www.bostonmoto.com
    Senior Member cdseven95's Avatar
    Ive had mixed luck with easy outs.... Break one in the bolt and its hell..
    MA/NH
    haha alright thanks
    Just ask, Be surprised!
    Jan 2009
    Salem, MA
    spray in PB (penetrating blaster)
    I found this in an Auto Shop such as Pep Boyz
    Then use the EZ out.
    If this does not work, then drill it out and rethread the hole for a new bolt.
    If you do not have those tools on hand, then paying someone who does may be cheaper than purchasing these tools for your own use. If you plan to shear the heads off of lots more bolts, then get the tools and learn to do it on your own.
    If there is a way to dremel a slot in the remaining piece - try that first with a straight blade screwdriver.
    If not, or if that doesn't work - Ez Outs have never failed me.
    You want to use the biggest one that will grip without touching the threads.
    Drill a hole that will let the EZ out go in as much as possible, while still leaving enough meat for it to bite into.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Member Hammerspur's Avatar
    Nov 2009
    Cranston,RI
    Quote Originally Posted by cdseven95 View Post
    ...easy outs.... Break one in the bolt and its hell..
    Quote Originally Posted by Danz19899 View Post
    if you have somewhere that will do it for cheap go for it...
    "A skittish motorcycle with a touch of blood in it is better than all the riding animals on Earth."
    T.E. Lawrence
    Definitely soak it in pb and walk away before you try anything. Repeat, and then do as Tony says. Make sure you use a nice sharp punch before you start drilling.
    The pb soaking and the vibes from drilling should loosen it up. You may even see the bolt spin with the drill till it bottoms out. Keep going, just don't drill through the bolt and what's now behind it.
    Patience is key.
    Central MA
    Real Dirt Bikes do not have oil filters.
    Center punch the broken bolt as best you can, drill with a very small bit, and only go as deep as you have to. Try not to let the bit walk to the edge of the stud. Gently heat around the bolt with a propane torch if the stud does not budge with an EZ-Out. Usually, the drilling generates enough heat to let the stud back out easily.
    Lifer obsolete's Avatar
    Norf Sho
    Drill exactly in the center!. Use a good punch to get get the bit started in the center. I tend to have my buddy extract bolts in vital stuff for me because I do not have the patience for it.
    -Alex
    Mar 2004
    woonsocket ri
    I have never had luck with eazy outs so now I bring it to someone to take them out. How hard did you think you had to put that bolt in superman?
    one armed son of a Sprock's Avatar
    York
    Drill the bolt dead center, a good size hole,......then hammer in a slightly bigger TORX bit
    and back out the busted stud/bolt
    Cost one messed up Torx bit maybe !
    Has worked great for me in the past
    "It may be that your sole purpose in life is simply to serve as a warning to others"
    1990 Honda CBR1000F "Hurricane"
    andrew
    Guest
    Quote Originally Posted by Sprock View Post
    This & left handed drill bits . They work in reverse. Sometimes they will catch the bolt & spin it right out .
    perfect timing...check out a thread here:
    http://www.thumpertalk.com/forum/thr...o-i-get-it-out
  1. Dropped bolt
    By 02redhawk in forum Bike Maintenance
    Last Post: 07-31-18, 12:56 PM
  2. Which bolt is it ?
    By danny86 in forum General Bike Related
    Last Post: 09-02-12, 07:10 PM
  3. WTB: Banjo Bolt
    By jcbell1007 in forum Wanted
    Last Post: 04-12-11, 12:21 AM
  4. flywheel puller bolt snapped...
    By gamorg02 in forum General Bike Related
    Last Post: 02-07-11, 06:43 PM
  5. New Bolt On for Jim
    By csmutty in forum General Bike Related
    Last Post: 01-08-10, 06:39 PM
