I wish to remove the Circlip that holds the gear shift lever to the shift rod on a 2008 Suzuki SV650. See attached photo.
Is there a special tool for this or can I pop it off with a flathead/other with little fear of damaging it? (I do understand that they are cheap to replace.)
Thanks
/s/ Dustin
LRRS #767
'09 R6 / '11 848 Evo / '99 RS250
I have a set you can borrow if you need.
Zip Tie Alley Racing #444
Signature edit by Tricky mike
/s/ Dustin
LRRS #767
Thanks, Jim. I spent the better part of last night using standard techniques (lever pumping, bleeding, tapping, leaning, squeezing, cracking, swearing, drinking) to refill the brake-fluid system, and when I finally zip-tied the lever and went to bed, I only had about 50% brake pressure. If things don't get better tonight, the vacuum bleeder, manual or otherwise, will become last resort. However, it looks like one of the guys going to Monti has one.
/s/ Dustin
LRRS #767
Dustin???
I have both loaner tools here.
Not rude, appreciate the suggestion. I do have a bleed screw on the master/bar mount, and bled that in concert with the screws at the calipers. Seemed to get a solid bleed from there as well.
What happened is that my primary caliper has a frozen brake-pad retainer pin that I haven't yet been able to extract/drill (see other thread). But I received a lot of spares with the bike and so drained the front brake system, removed primary caliper, mounted a spare caliper, and tried to refresh the system. Made about 50% progress. Torque the banjo to spec. Since the spare is not leaking brake fluid around the pistons, I've assumed that my problem is a basic one: air caught somewhere, perhaps in between the reservoir and the master. Will approach it fresh tonight.
/s/ Dustin
LRRS #767
Sv?
I have a Full Brake System 2 Calipers SS Lines New pads sitting in a box in My garage.
Need any
