Results 1 to 25 of 32
storing bike w water/coolant
    live to ride seth399's Avatar
    Feb 2007
    CA
    Hey just wondering what people do that store their bike in a garage or whatever over the winter that see freezing temps. The bikes on the track need to run water in the cooling system so do you just drain it over winter or put in a water/coolant mix while it sits?
    My mx bike always has coolant (not straight water) and I haven't had an issue storing that and having it freeze/f up the bike.
    thanks
    LRRS #399
    MX #505
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Re: storing bike w water/coolant
    i use straight coolant but i dunno if that is the right answer
    Feb 2007
    CA
    sounds good to me..just wanted to double check and not kick myself for not draining it dry or something.
    LRRS #399
    MX #505
    Lifer Pittenger5's Avatar
    Austin
    I was wondering the same, my garage doesnt get to freezing, but I've always just put coolant in the race bike, but itd be a million times easier to just drain it, is there any harm in leaving it drained?
    Problem with coolant is you hafta flush it next season again. Leaving it drained would just be a lot easier.
    Zip Tie Alley #505
    Raymond NH
    Oddly, straight coolant has a higher freezing temperature than coolant mixed with water. Ethylene glycol, the chief ingredient in anti-freeze, freezes solid at 8 degrees F. See: ETHYLENE GLYCOL and look for "melting point" under "physical and chemical properties". When mixed with water at 50/50, it should remain liquid to at least -40 degrees.
    Manvile, RI
    i dont think you ever drain it completely.
    Raymond NH
    Problem with just leaving it drained is that there may be a pocket of water that does not drain out. Found this out the hard way with my boat engine... To be safe, drain the water and fill the cooling system partially with RV/Boat storage anti-freeze. It's non-toxic so disposal is easy, and cheap.
    Austin
    Quote Originally Posted by bigred875 View Post
    Kind of what I figured, but Im very lazy so I thought I might try to get the easy way out.
    Zip Tie Alley #505
    Manvile, RI
    I did the straight coolant on an ex race bike i had...i typically leave whats in the streetbikes, which is a 50/50 mix...guess i'll be doing that from now on
    50/50 mix in there for the winter. It will keep your water pump seals conditioned.
    Draining it will allow the seals to dry, and deposits to form that will reduce the systems effectiveness over time.
    Posting Freak Puppet's Avatar
    Oct 2004
    Seattle Area
    Yup...drain the water/water wetter mix and use a 50/50 anti-freeze (most coolant you buy is pre-mixed anyway). I run engine ice in the street bikes all year, but for the race bike, I just use some cheap mc anti-freeze since it gets changed anyway before the bike gets run again.
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Feb 2007
    CA
    perfect...thanks guys
    LRRS #399
    MX #505
    Meriden, Ct
    Switch to Engine Ice or some other non-glycol coolant, and leave it in there year round.
    Lifer BostonSVkid's Avatar
    Dec 2005
    FYI make sure when you are mixing your coolant that you are using Deionized water because if you dont your radiator will rust over time. When I got my trumpet the idiot before me didnt and I had to flush the system 4 or 5 times to get it clear. Then I just put engine ice in.
    2006 Ducati Monster S2R800
    Oct 2004
    Seattle Area
    Not LRRS legal
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Meriden, Ct
    Quote Originally Posted by Puppet View Post
    Not LRRS legal
    Oh... Oops...
    Oxidation of the aluminum components. Not worth leaving it drained, IMO.
    Lancaster, CA
    +1 Don't leave it drained. It'll only take a few more minutes to fill it up, then maybe an extra hour to flush it in the spring. Cheap insurance.
    Leave water wetter in and store bike in living room
    The Fastest Indian! kamikaze's Avatar
    Jul 2008
    Delhi, Indiaaahh!
    Same applies to street bikes? What should one do with the street bike? Should I change the coolant I have right now or keep it and change it in beginning of next season?
    Sold: 1999 Kawasaki ZX-7R
    2005 Pulsar 180 DTSi
    Owning: Pulsar 220 DTSi
    http://www.dhairyagupta.com
    http://bostonbiker.blogspot.com
    Just Registered Omahastylin16's Avatar
    Apr 2008
    Scituate, MA
    mine camps in my bedroom for the winter
    "Chatbox...It's like Vegas, for your fingers."
    Originally Posted by CBR_Knight
    in my own thread, let me post this:
    first of all, nothing about sex or play with a female seems interesting or arousing to me....
    "BALLS" is coming home late after a night out with the guys smelling of perfume and beer, lipstick on your collar, slapping your wife on the ass and having the balls to say "you're next!"
    Feb 2007
    CA
    Quote Originally Posted by kamikaze View Post
    street bike should already have coolant/water mix so leaving that would be fine.
    LRRS #399
    MX #505
    Quote Originally Posted by Omahastylin16 View Post
    Glad I'm not the only weirdo that does that
    Junior Member Paintman's Avatar
    Belchertown/Amherst
    Haha, do you always leave the TV on for the bike to watch when you aren't home?
    1986 Yamaha FZX700S (the original Fazer)
    He must be single...
  1. Coolant flush and refill with distilled water?
    By kumpy in forum Bike Maintenance
    Last Post: 10-05-12, 11:18 AM
  2. Storing a track bike
    By Baggey22 in forum General Track Day Talk
    Last Post: 05-31-12, 04:57 PM
  3. Storing Motorcycle Filled w. Water Wetter
    By Eddie in forum General Bike Related
    Last Post: 01-31-11, 01:34 PM
  4. Storing A Bike The Right Way
    By S4R_GRL in forum General Bike Related
    Last Post: 03-15-09, 02:35 PM
  5. Storing the bike in a condo?
    By Bster in forum General Bike Related
    Last Post: 11-11-06, 08:50 PM
