Results 1 to 13 of 13
How tight do head bearing nuts go on?
    Posting Freak yesterdayze's Avatar
    Milton Vermont
    Question How tight do head bearing nuts go on?
    Okay, replaced the head bearing on my bike last night. No big deal, put on some all balls tapered ones. Done tons of bike work, just not ever needed to do head bearings. What I am unclear on is the nut that goes right on top that sets the torque on the head bearings... how tight should this be? I have read people saying 'tighten till it is to hard to go further then back off a half turn' and people saying 'finger tighten, but no force'. Both seem extreme.
    Anyone actually know? It's 98 GSXR SRAD if that matters...
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    Re: How tight do head bearing nuts go on?
    When I did mine I tightened till I couldn't then I backed off a bit and checked the steering for smooth movement. When it felt like it did turning before I did the job it set it and tightened the top bolt down.
    Milton Vermont
    Quote Originally Posted by slammp View Post
    That is basically what I did I just wasn't sure.... have you had any trouble since?
    Milton Vermont
    So I finally found the torque specs...they call for 45nm.... Not sure how the hell I'm supposed to measure 45nm's with a tool that doesn't have anyway of hooking up to a torque wrench... guess we'll go with the wing it method... lol
    Jul 2008
    Massachusetts
    i've had no trouble, but i did check it again after the first 50 miles to make sure it didn't back off at all.
    who knows
    When putting my buddies 600RR head set back together we took the spanner wench for the rear shock that fit in the notch of the head seat nut and with a dremel I notched a square in the handle so i could put my torque wrench on it.
    Wirelessly posted (BlackBerry8530/5.0.0.508 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
    Pm dbkromz. He has the special tool for that.
    Lifer Currently's Avatar
    Ooltewah, TN
    My factory manual says to use a fishing scale and when it takes "x" amount of tension to move the clipon, you have the right torque on it.
    SV650
    If loud pipes save lives, imagine what learning to ride would do.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Quote Originally Posted by yesterdayze View Post
    Those nm's are on my torgue wrench. I have never used them.
    Quote Originally Posted by scubasteveRR
    You changed the fulcrum so your torque reading needs to be adjusted I believe.
    Quote Originally Posted by Currently View Post
    SV650
    That's the method I use.
    Milton Vermont
    Hmmm.... well, I didn't have a good tool to do it with and am a ways away from dbromz so I just tightened it down till it still could go further but was definetely tight then I backed it off 1/2 - 3/4s turn and made sure it turned smoothly and that I couldn't shake anything. Still tight but not 'brake it' tight. Def more then 'finger' tight though.
    I'm hoping it's okay. I took it for a test run - (without fairing.... mirrors... blinkers... anything... cops would have loved that) and it seemed fine....
    I do this stuff a lot though so I will doubtless have more head nuts like that to deal with so I suppose I will get the tool. I'll try getting a scale as well. Any recommendations on a good tool?
    Jul 2008
    Massachusetts
    just get a large adjustable plumbers pliers (the ones with the grooves in the jaw for different width) and make sure you get rubber handled so it does not scratch. Thats what i use, works fine.
  1. Getting tight...
    By markbvt in forum Vermont Events
    Last Post: 05-26-10, 07:35 PM
  2. Bad Head bearing
    By 00cbr_f4 in forum Bike Maintenance
    Last Post: 07-28-09, 07:54 AM
  3. steering head bearing replacement with pics...no 56k.
    By dwaltz61 in forum General Bike Related
    Last Post: 09-10-08, 11:57 AM
  4. steering head bearing replacement...
    Last Post: 08-21-08, 07:28 PM
  5. Steering Head Bearing
    By Devil1 in forum Bike Maintenance
    Last Post: 05-12-08, 05:18 PM
