Results 1 to 23 of 23
vibration on my street bike
    2002 GSX-R 600 with 33k miles, PCIII, and never checked valves.
    the map was done years ago at RJ's in NH.
    this morning i'm getting a bad front vibration at 10k+ RPM in 4th, and 8.5k+ in 5th and 6th.
    possibilities:
    • map went bad (but unlikely)
    • injectors clogged
    • front wheel balance
    • dirty air box
    • dirty spark plugs
    • valve clearance?
    i could run an injector cleaner in my next fill up. if that doesnt help, then i could take off the upper & lower injectors to a cleaning service.
    if the front tire wasnt balanced properly, wouldnt that vibration happen at all RPM ranges or speeds?
    would a bad valve gap cause a vibration at a high RPM?
    any other ideas/possibilities this might be?
    TWINS! xrocket21's Avatar
    Central Maine
    Re: vibration on my street bike
    my vote is spark plugs
    Under higher loads, a weak spark will fail.
    Meriden, Ct
    My vote is to launch that POS off of a cliff or bridge.
    Swap plugs and for god sakes check the valves. I'd check the airbox as well. My SV was FILLED to the brim with dog food last time we had a cold spell.
    2016 BMW S1000XR
    Central Maine
    checking valves is for pussies
    Aug 2009
    Hillsborough County, NH
    Throttle bodies need to be synced?
    🇯🇵 2001 Honda CBR 929RR R.I.P
    🇯🇵 2009 Honda CRF 250X
    🇯🇵 2013 Kawasaki Ninja ZX636R
    🇦🇹 2016 KTM 1190 Adventure-S
    If it's a tire balance, it can happen at a certain speed... But it would be regardless of RPM. So if you go X speed and get the vibration... Then shift two gears but stay at the same speed... That will determine if it's tire related.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Power off. Take battery off. Reinstall. Turn on.
    Nov 2006
    Cape Cod
    warped front rotor / rotors
    Lifer bbhzx10's Avatar
    Jul 2004
    North shore
    Scalloped tire and or wheel/steering bearing possibly. Easy to check at least
    2001 Silver ZX-12R... RIP
    2005 KDX 200
    cleaning my chain last night, and i noticed this chain is junk. it has some tight spots on it, which easily could've caused the vibration.
    think i've had it for 5 years now and about 20k, so it's due.
    Lifer Ductard's Avatar
    Sep 2013
    South Boston, VA (not a typo)
    You gonna get new earplugs while you're at it?
    LRRS 919
    i have a pack of new ones in my gear bag. i like to use the old nasty ones because it bothers Brett.
    if you heard my street bike, i'd need to double up on ear plugs.
    Meriden, Ct
    Do you notice the vibration at other times of the day? Like, say...At your desk? While filling your face with Chipotle? Watching tv?
    I'm just trying to isolate where the strange vibration is coming from.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    i'm gonna rub them on my nuts after the hottest day at the classic next year.
    no wait I don't want to do that. I don't need my nuts to get an infection
    Raymond NH
    One other thing to check: Look for a broken or loose engine mount bolt. The engine is a stressed member of the fame assembly and if it's not secure, it can act like a tuning fork and set up a sympathetic vibration at certain RPMs/loads.
    Central Maine
    please update us when you figure out what it was, I keep checking this thread and keep getting blueballed. Im curious what it was.
    fairly certain it's the chain. it's more noticeable in lower speeds now that i know it's got a tight spot.
    that's the first thing i replace, but most likely wont be this season.
    Central Maine
    I figured it was too after what you said it looked like, was just curious if thats all it was.
    I like threads like this, next time I have a strange vibration, Ill think to check the chain, you know?
    put a new chain on a few weeks ago and finally rode to work today. the vibration was coming from a kink in the chain. it's smooth as buttah now.
    feels like my front tire is slightly out of balance now, but i've got another set to put on next time i go to the track.
    Bridgewater, MA
    and you put the chain on all by yourself
    actually still getting a vibration and no pull around 100.
    might have to check the plugs & possibly clean the injectors
  1. For Sale - Motorcycles | 2003 CBR600RR Track Bike/Street Bike
    By tucktuvak in forum For Sale
    Last Post: 01-21-20, 10:36 AM
  2. Replies: 2
    Last Post: 11-07-13, 05:42 PM
  3. New vibration in bars
    By GingahNinjah in forum General Bike Related
    Last Post: 07-22-13, 11:35 AM
  4. Street Bike to Track Bike Time Lapse
    By Jason P. in forum General Bike Related
    Last Post: 05-29-12, 08:31 PM
  5. Bar Ends & vibration
    Last Post: 07-16-06, 08:59 AM
