Results 1 to 7 of 7
Gear Indicator installation
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Guys,
    I've been thinking about installing one on my bike because i'm getting tired of keeping track of what gear I'm in while I'm riding.
    How do they install? How do they know what gear you are in?
    Re: Gear Indicator installation
    Originally posted by BadBoyBilly
    Guys,
    what difference it make what gear your in?
    Only time i need to know what gear i'm in is when i'm coming to a stop, or if i'm on the highway & wanna be in 6th... in either case I just click till it doesn't click any more aside from those two instances it doesn't matter to me much. only thing a gear indicator would do for me is instantly satisfy my curiosity.....
    i'm not that curious
    Just Registered FireFly's Avatar
    hehe
    Originally posted by OreoGaborio
    +1
    Lifer burnham's Avatar
    massachusetts
    they make some models that plug into the harness, the rest you have to splice in. Napa has some heat shrink with solder built in, I user these. It's a digital display, and it takes about two or three seconds at each gear change. I installed mine after riding cross-country, I tried to hit seventh gear a thousand fucking times and thought this would help. It's just a distraction (imo) I wouldn't want it at a track day.
    granite state
    [QUOTE]Originally posted by burnham
    [B]I tried to hit seventh gear a thousand fucking times
    i fucking hate that! thats the only reason i would want one.
    Lifer ZX-12R's Avatar
    Candia, NH
    Guys,
    First off, if your bike has an ECU for fuel injection then it will likely have a gear position sensor. I can't say what all bikes have but all of the ones I have seen have been a rotary switch that grounds one of 6 or 7 wires depending on if your transmission is a 5 or 6 speed (1-5 and neutral or 1-6 and neutral).
    All the system does is recognize which wire is pulled low and displays it on a seven segment display. The good systems will give you a cable that will hook in-line with the main connector on your ECU. The cheaper ones will have you splice into your harness. If you have any doubt in your wire splicing skills, definitely pay the extra money for one with a pre made cable.
    They are also very easy to make. I made a microcontroller based one for a friend of mine that also acted as an adjustable shift light. Unfortunately the hardest part is making the display look like it was installed at the factory.
  1. Gixxer gear position indicator
    By gadget in forum General Bike Related
    Last Post: 06-21-18, 12:41 PM
  2. Wanted - Parts & Tools | Gear Indicator (Ducati 750 SS)
    By norco4hun in forum Wanted
    Last Post: 08-22-14, 03:39 PM
  3. FS: Acumen Gear Indicator - RED Display
    By MMPeter in forum For Sale
    Last Post: 12-08-08, 11:26 PM
  4. ATRE / Gear indicator for Hayabusa and others
    By Josephd14 in forum For Sale
    Last Post: 03-20-07, 05:48 PM
  5. Gear Indicator ?
    Last Post: 05-18-06, 10:51 PM
