Results 1 to 25 of 39
TCP Port 80??
    Just Registered Doc's Avatar
    Jericho, VT
    TCP Port 80??
    Seems my IP may be blocked to NESR
    I get some message that says a firewall isn\'t allowing me or some such and that the fiewall admin should enable TCP 80...
    Any ideas?
    Re: TCP Port 80??
    So... how'd you post this?
    And I doubt it's NESR generating that message, look closer to home.
    Jericho, VT
    Re: TCP Port 80??
    Proxy server.
    I get a message that Internet Explorer cannot display the web page...
    I click diagnose and I get a windows diagnostics message that says NESR is online but not responding to my connection. Also says my firewall is working properly to allow the connection but a remote firewall might be blocking the connection.
    It then says if I have acces that i should configure the firewall to allow connections thru TCP port 80...
    I have ,messed with my firewalls (of and on), tried an IP release and renew and nothing...
    I get ever other site BUT NESR (without the proxy server). I get it at work and on my phone without problems as well.
    I think something is blocking me but I can\\\\\\\\\\\\\\\'t figure out what.
    Lifer Danz19899's Avatar
    Grafton, Ma
    Re: TCP Port 80??
    Proxy server.
    found your problem . . . download firefox see it it works on a different browser
    www.bostonmoto.com
    Ride to live, live to ride
    Re: TCP Port 80??
    either that, or go into your router and turn off all firewalls so there's no blocked traffic.
    Lifer NobodySpecific's Avatar
    Apr 2008
    Burlington, VT
    Re: TCP Port 80??
    I'm assuming this is at home? How long has it been like this? Did you change any hardware around the time that this started happening (router or cable modem)? What are you running for a software firewall (if any)?
    I would definitely try another browser before doing anything else.
    '06 Triumph Sprint ST ABS
    '90 Yamaha XT350
    Jericho, VT
    Re: TCP Port 80??
    Yep is at home. No new Hardware, Firewall is Norton. I may have had some software updates recently.
    Apr 2008
    Burlington, VT
    Re: TCP Port 80??
    Norton sucks. Is it a laptop or desktop? If you bring it to bike night and it is a problem on the computer itself I'm certain somebody would have it fixed before you left. Do you go through a router or just the cable modem? It's possible that you accidentally changed the settings on the router, though highly unlikely. I could swing by and take a look, but I'm not sure I could fix it.
    '90 Yamaha XT350
    Jericho, VT
    Re: TCP Port 80??
    Yes I go through a router. I don\'t know how I would have changed the settings...
    Come on by. I am home all day.
    Apr 2008
    Burlington, VT
    Re: TCP Port 80??
    Well I'm at work, but I should get out around 5 so I can swing by after that. Have you tried using Firefox?
    '90 Yamaha XT350
    Jericho, VT
    Re: TCP Port 80??
    I have tried Firefox in the past. Not recently though.
    Life is good! gadget's Avatar
    Nov 2008
    Londonderry
    Re: TCP Port 80??
    Port 80 is HTTP access.
    If you can reach any regular site with http:\\ then port 80 is open and you do not need to mess with it. This suggests that your PC is blocking access to this specific site.
    Try deleting temporary internet files and history.
    This is located under Tools>Internet Options. On the first Tab select Delete under "Browsing History"
    Using another Web Browser like Firefox would bypass this step.
    Also, take a look at Norton Firewall and check to make sure the this particular website is not being blocked. The reason I suggest looking at Norton Firewall is that it is likely that your error is being reported by Windows and it is not identifying the Norton Firewall as being local.
    Sam
    Apr 2008
    Burlington, VT
    Re: TCP Port 80??
    Quote Originally Posted by gadget View Post
    This is why I keep asking Doc to try Firefox, because I thought if it was IE settings that got messed up this would bypass that. Yet all he says is that he's used it in the past. It will take 30 seconds to try...
    '90 Yamaha XT350
    Wirelessly posted (BlackBerry Giggity: BlackBerry8330/5.0.0.438 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/104)
    Port 80 is web traffic. You're trying to say you can't get on the internet at all without bypassing everything by goung through a proxy? And I assume the proxy is using port 443 if you can't use 80.
    Doc sucks
    Administrator Frankenstein's Avatar
    NH
    Re: TCP Port 80??
    Doc, PM me the external IP that's having this issue. I've got some fairly strict security checks running on this server so based on what you've told us, it's possible/likely that you got squashed by the firewall or mod_security.
    Forum Rules || Stop. Think. Post.
    NH
    Re: TCP Port 80??
    Nevermind, I found it. mod_security detected PHPB Worm SQL injection attempts from your system so you got blocked by the firewall.
    Here's the log entry (cleaned up for the sake of privacy):
    Time: Wed Oct 6 10:12:23 2010 -0400
    IP: x.x.x.x (US/United States/c-x-x-x-x.hsd1.vt.comcast.net)
    Failures: 5 (mod_security)
    Interval: 300 seconds
    Blocked: Yes
    Log entries:
    [Wed Oct 06 10:11:35 2010] [error] [client x.x.x.x] ModSecurity: Access denied with code 403 (phase 2). Pattern match "(?:\\x27|%27|\\x2527|%2527)" at ARGS:highlight. [file "/usr/local/apache/conf/modsec/99_asl_jitp.conf"] [line "5657"] [id "310080"] [rev "1"] [msg "Atomicorp.com - FREE UNSUPPORTED DELAYED FEED - WAF Rules - Just In Time Patch: PHPBB worm"] [severity "CRITICAL"] [hostname "www.nestreetriders.com"] [uri "/forum/bike-night-vermont/58882-docs-garage-tear-down-rebuild-thread-8.html"] [unique_id "TKyDl60tddIAAA5zL24AAAAH"]
    [Wed Oct 06 10:11:40 2010] [error] [client x.x.x.x] ModSecurity: Access denied with code 403 (phase 2). Pattern match "(?:\\x27|%27|\\x2527|%2527)" at ARGS:highlight. [file "/usr/local/apache/conf/modsec/99_asl_jitp.conf"] [line "5657"] [id "310080"] [rev "1"] [msg "Atomicorp.com - FREE UNSUPPORTED DELAYED FEED - WAF Rules - Just In Time Patch: PHPBB worm"] [severity "CRITICAL"] [hostname "www.nestreetriders.com"] [uri "/forum/bike-night-vermont/58882-docs-garage-tear-down-rebuild-thread-8.html"] [unique_id "TKyDnK0tddIAABFGKjMAAAAJ"]
    [Wed Oct 06 10:11:45 2010] [error] [client x.x.x.x] ModSecurity: Access denied with code 403 (phase 2). Pattern match "(?:\\x27|%27|\\x2527|%2527)" at ARGS:highlight. [file "/usr/local/apache/conf/modsec/99_asl_jitp.conf"] [line "5657"] [id "310080"] [rev "1"] [msg "Atomicorp.com - FREE UNSUPPORTED DELAYED FEED - WAF Rules - Just In Time Patch: PHPBB worm"] [severity "CRITICAL"] [hostname "www.nestreetriders.com"] [uri "/forum/bike-night-vermont/58882-docs-garage-tear-down-rebuild-thread.html"] [unique_id "TKyDoa0tddIAABFFJdMAAAAG"]
    [Wed Oct 06 10:11:51 2010] [error] [client x.x.x.x] ModSecurity: Access denied with code 403 (phase 2). Pattern match "(?:\\x27|%27|\\x2527|%2527)" at ARGS:highlight. [file "/usr/local/apache/conf/modsec/99_asl_jitp.conf"] [line "5657"] [id "310080"] [rev "1"] [msg "Atomicorp.com - FREE UNSUPPORTED DELAYED FEED - WAF Rules - Just In Time Patch: PHPBB worm"] [severity "CRITICAL"] [hostname "www.nestreetriders.com"] [uri "/forum/pit-area/55882-kurlonizing-classic.html"] [unique_id "TKyDp60tddIAABElHa8AAAAK"]
    [Wed Oct 06 10:12:19 2010] [error] [client x.x.x.x] ModSecurity: Access denied with code 403 (phase 2). Pattern match "(?:\\x27|%27|\\x2527|%2527)" at ARGS:highlight. [file "/usr/local/apache/conf/modsec/99_asl_jitp.conf"] [line "5657"] [id "310080"] [rev "1"] [msg "Atomicorp.com - FREE UNSUPPORTED DELAYED FEED - WAF Rules - Just In Time Patch: PHPBB worm"] [severity "CRITICAL"] [hostname "www.nestreetriders.com"] [uri "/forum/bike-night-vermont/58882-docs-garage-tear-down-rebuild-thread.html"] [unique_id "TKyDw60tddIAABFJKvcAAAAO"]
    Just Registered drop's Avatar
    Bradford, MA
    Re: TCP Port 80??
    doc has worms.
    - Jamie
    2009 K 1300 S
    Wirelessly posted (BlackBerry Giggity: Mozilla/5.0 (iPod; U; CPU iPhone OS 3_1_2 like Mac OS X; en-us) AppleWebKit/528.18 (KHTML, like Gecko) Version/4.0 Mobile/7D11 Safari/528.16)
    Looks like Doc's IP sucks too
    Re: TCP Port 80??
    Quote Originally Posted by Frankenstein View Post
    Looks like Doc's just a virus.
    Re: TCP Port 80??
    Blocked: Yes
    Damn, guessed wrong, it WAS NESR generating the error. D-oh!
    Apr 2008
    Burlington, VT
    Re: TCP Port 80??
    Needless to say I will not be swinging by after work today
    '90 Yamaha XT350
    Jericho, VT
    Re: TCP Port 80??
    So I have worms or a virus?
    NH
    Re: TCP Port 80??
    That's what the scan logs suggest, yeah. The detection rules I use (ASL from gotroot.com) have been solid so far, no false positives that I've seen.
    Jericho, VT
    Re: TCP Port 80??
    Ok, I ran Norton Anti virus and downloaded AVG as well...
    Didn't seem to fix the issue. Any other suggestions?
    Don't treat your PC like a Hawk
  1. Cisco 5-Port 10/100/1000 Switch SD2005 $39.99
    By imstuner in forum For Sale
    Last Post: 09-11-12, 05:09 PM
  2. Port Henry, NY-to-Montreal routes?
    By Hinesy in forum Rides & Events
    Last Post: 06-09-06, 04:17 PM
