Results 1 to 14 of 14
Car starting problem
    Nov 2004
    Boston, MA
    Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_2_6 like Mac OS X; en-us) AppleWebKit/533.17.9 (KHTML, like Gecko) Version/5.0.2 Mobile/8E200 Safari/6533.18.5)
    It's an 07 escalade, battery is probably a year old. Anyhow last week it wouldn't start, lights all came on, radio etc but it just clicked and no crank at all. An hour later it started fine. No jump or anything. Today won't start again.
    Could it be the battery - just seems odd as it's a newish battery and all the electronics are fine.
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Re: Car starting problem
    Check connections for corrosion?
    Member stpierre's Avatar
    Sep 2011
    Laconia N.H.
    Yup..
    Look at the headlights are they dim?
    What up, bitches?
    .... duey's Avatar
    Wilmington MA
    Is the immobilizer light flashing? If so it could be an issue with that.
    2021 Ducati Panigale V2
    2020 Honda Grom
    Castleton, Vt
    I would try to get a multimeter on the starter when it isn't starting. If your getting 12 volts to the starter when you turn the key, the starter is bad.
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    Holy double threads Batman!
    Derry NH
    Does the starter repeatedly click when you try to start it? Or does it click only once?
    If it clicks repeatedly, it's likely a bad connection somewhere, likely the battery terminals.
    If it only clicks once, it's the starter.
    Quote Originally Posted by slammp View Post
    I just figgered he got it started then got stranded a second time
    Lifer Rosco61's Avatar
    Oct 2007
    Peabody Ma
    Next time when it won't start whack the starter with a dead blow mallet or something similar and try it. Sometimes when they are going bad they have a dead spot and whacking it <the starter that is> can free it up and get you going.
    Nov 2004
    Boston, MA
    Quote Originally Posted by Eric Baker
    It clicks only once.
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Old School Fool. ZX11D's Avatar
    Jan 2009
    Wilmington MA
    I think it`s the starter also. Could be something else but if you have everything else IE;lights the logical conclusion would be something to do with the starter. Sounds like the bendix spring is not pushing the starter all the way into the flywheel ( 1 click). Common problem and not a big job.
    Nov 2004
    Boston, MA
    Thanks folks. Waiting on the mobile roadside tech - hopefully it's not some tool with a jump box and they can get it fixed without a tow. Probably the only perk of owning a Cadillac!
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Mar 2011
    Starter!
    Nov 2004
    Boston, MA
    Starter is right! Guy is wiggling and jiggling it and it started. He thinks there is a loose connection.
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
  1. Car starting problem
    By Manny in forum Off-Topic
    Last Post: 11-07-11, 11:54 AM
  2. Ducati 749 - Starting Problem
    By KillBill in forum Off-Topic
    Last Post: 08-28-08, 11:00 PM
  3. Starting Problem
    By 97BlownSaleen in forum Bike Maintenance
    Last Post: 08-03-08, 07:25 AM
  4. starting problem...
    By JunoAF in forum Bike Maintenance
    Last Post: 07-03-08, 06:37 AM
  5. Starting problem with the '84 Ninja 900
    By Ericthejet in forum Bike Maintenance
    Last Post: 09-27-07, 08:01 AM
