Page 1 of 2 1 2 LastLast
Results 1 to 25 of 29
Leaves
    Lifer Pittenger5's Avatar
    Austin
    Leaves
    I hate raking. Whats to say I cant just mow the fuckers over and turn them to mulch? Or use the bagging attachment and do it that way?
    Serious question, can I do these and be effective enough to not kill my lawn?
    Zip Tie Alley #505
    Nov 2009
    Bristol County
    Re: Leaves
    Mow your lawn in a circle, blowing the results towards the same location. When you're done, you'll have the left overs in a relatively small area. Re-mow them. Done. For best results, be sure your mower's blades are nice and sharp, and that you have done a good job cleaning the underside of the deck, as this will promote the finest "mulching".
    If you have an absurd amount, run it with a bagger.
    It is best not to use a bagger though, as dropping the the grass blades on your grass promotes water retention and creates a layer of quality dirt as it decomposes. The same logic can be applied to your leaves. I'd say you should be good to go.
    You trying to rub some road salt in the wound? :p
    nedirtriders.com
    Senior Member Bkilm's Avatar
    Southern NH
    Re: Leaves
    If you use the bagging attatchment there should be no problem as long as you dont have a crappy lawnmower.
    Black/Green 09 600RR (street)
    03 600rr (Track)
    Anyone here ever had to do an emergency figure "8"?
    Quote Originally Posted by KawiSmurf View Post
    Yah, I was being chased by bee. He was too quick to lose on the first u-turn, but I ditched him on the second one.
    Lifer ZX-12R's Avatar
    Candia, NH
    Wirelessly posted (BlackBerry 9530: Opera/9.80 (BlackBerry; Opera Mini/5.19692/26.1283; U; en) Presto/2.8.119 Version/10.54)
    Baggers work but if you have a big lawn and a lot of leaves, you will be emptying it so often that it will start to piss you off. Several years ago I bought Husqvarna's largest backpack blower they make and I haven't looked back since.
    Southern NH
    Re: Leaves
    Hes not clipping his grass hes picking up leaves
    03 600rr (Track)
    Austin
    Re: Leaves
    Well, 90% of our grass is dead from the drought, but we're finally getting rain again, so I want to try to clear up the grass a little bit anyway. Guess Ill just mulch the bastards.
    Zip Tie Alley #505
    Lifer Stromper's Avatar
    Eastern Ct
    Re: Leaves
    On a treed lot I had an 8 to 1 chopper and it was still 3 pick up loads.
    Only a tow behind sucker bagger really works
    Stihl back pack blower is the only on that really works.
    ZEN, Its there, you need exercise, Yaweh provides.
    IF you grind it into the lawn that's OK assuming the grinded still allows air and sunlight down to the grass. If you cover grass for more than 2 weeks its dead. The composting products are acidic so you would have to lime in the early spring... you probably should lime anyway
    The calculus of hate
    Austin
    Re: Leaves
    Oh and Ill add, I dont have the disposable income to buy new tools or hire mexicans. So thats out.
    Zip Tie Alley #505
    Jun 2005
    Re: Leaves
    you need an efficient leaf moving operation...
    Nov 2009
    Bristol County
    Re: Leaves
    Quote Originally Posted by Bkilm View Post
    Which part of "The same logic can be applied to your leaves" did you need help understanding?
    nedirtriders.com
    Austin
    Re: Leaves
    I am not Tricky enough for such an operation.
    Zip Tie Alley #505
    Jun 2005
    Re: Leaves
    it's a lawn tractor with ATV tires
    May 2007
    Southern NH
    Re: Leaves
    My biggest objection is God didn't see fit to have 'em all fall at the same time....and, how come the smallerthe kid the greater the energy - and the older you get the less. Seems like a design flaw to me....!
    Muhammad Ali.
    Austin
    Re: Leaves
    I actually wouldnt mind raking the leaves, but I already have lower back issues, and raking destroys me like no other.
    Zip Tie Alley #505
    Wistah
    Re: Leaves
    Nov 2009
    Bristol County
    Re: Leaves
    I know how you feel
    Focus on strengthening your lower back in general, same with stretching it. My guess is that your lower back is weak and tight, and the raking really shows it. Back when you were in NE, shoveling kill you too? Done PT?
    nedirtriders.com
    Austin
    Re: Leaves
    I know how you feel
    Yup, I think thats the issue, I slouch brutally too. Riding bikes hurts as well. And yes, shoveling was brutal, but at least I had a snowblower there.
    Zip Tie Alley #505
    South Coast MAsshole
    Re: Leaves
    i know what you mean...i despise raking...i guess it really depends on how much you have as far as leaves and how long your grass is underneath the leaves...i use a self propelled walk behind with a mulching blade and a bag and i dump the bag into a garbage can...the circle cutting method works pretty good too...blowers are great if you have an area to corral the leaves into, your grass is short and if it's not a windy day...other than that you probably waste more time using one than just running over them with a lawnmower
    all i can say is make sure the grass and leaves are dry or it's a pain in the ass
    Point37s Garage Sale Thread
    Nov 2008
    Framingham, MA
    Re: Leaves
    I do exactly what Tricky demonstrated in his picture when I have too much accumulation. Otherwise I use my lawnmower to collect the leaves and dump them into the woods.
    Jul 2006
    Hollis, NH
    Re: Leaves
    I wouldn't mulch a damaged or dead lawn. You'll be dropping weed and tree seeds back into the soil and worse, covering them with a nice peat moss like substance (clippings). A healthy lawn can choke the weeds and tree seedlings but it doesn't sound like yours is like that. Pay a kid to rake them or bag them with your mower.
    My friends call me Buba CTRT's Avatar
    Dec 2010
    Averill Park, NY
    Re: Leaves
    Two words CYCLONE RAKE
    MMI Grad * Kawasaki K-Tech Certified * K-Tech Student of the Course * Yamaha 5 Star Certified * Yamaha Bronze Tech *Yamaha Student of the Course * DYNO-JET Certified
    Jul 2005
    Bennington, NH
    Re: Leaves
    We mow ours and our lawn is pretty freaking awesome.
    Just Registered
    Mar 2003
    Shrewsbury, MA
    Re: Leaves
    A couple weeks ago I bought an Echo 770 Backpack blower. It's awesome
    If you can't Race it or take it to bed, it's not worth having..
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Re: Leaves
    the mower will never produce results as good as raking. I despise all types of yard work so I tried the mower approach before and it just didn't work well enough cause I can be anal about stuff. If I'm doing it then I'm doing it right.
    Lifer Rosco61's Avatar
    Oct 2007
    Peabody Ma
    Re: Leaves
    Here's what I use. and yes it's awesome. 6.5 hp leave blower/vacuum.
    http://www.youtube.com/watch?v=VEeJ460y45U
  1. snow+leaves on trees
    By burnham in forum Off-Topic
    Last Post: 01-08-12, 08:44 PM
  2. LEAVES!!!!! be safe out there....
    By R1 in forum General Bike Related
    Last Post: 10-08-10, 08:24 AM
  3. Loose leaves tea drinkers
    By MissTwisties in forum Off-Topic
    Last Post: 04-02-10, 08:55 AM
  4. Another one leaves the party
    By Woodsy in forum Off-Topic
    Last Post: 10-02-08, 06:00 AM
  5. Ducati leaves AMA Superbike
    Last Post: 08-23-06, 03:10 PM
