Anybody take the free upgrade?
if so was it smooth and what is it
or is it like Vista
The calculus of hate
I had 8.1 installed and took the upgrade, super easy, seems to have sped up the laptop a bit too. I'm not techy enough to give you a big run down on changes, but I do like it so far.
2018 Harley Road Glide
2000 Ducati 900ss
I'm with PinHead. Upgrade was really easy, took a little while but that's to be expected (still less than half an hour). FWIW, I like the user interface better so far. Some things are taking some getting used to but only because they're different. Seems to be a cross between old windows and 8.1.
-Brian
15 S-Works Venge
I upgraded too. Not sure I can boast about more speed. Start up is certainly slower, but the new interface is what 8.1 should have been.
My upgraded system (8.1 prior) takes longer to fire up now. On the flip side I have clean Win 10 installs that boot far faster than 8.1 ever did on the same hardware so I think I'm going to blow away my main system and see how it likes a freshy-fresh install.
Gonna upgrade as soon as I pull the trigger on an external hard drive & back-up all my shiznit
Don't forget to avoid using the express setup option during installation, so you can disable all that privacy nightmare shit that makes windows 10 far worse than 8 ever was. MS is pharming like a mf'er with 10. Because, you know, the content of your emails will absolutely help MS improve your user experience.
*googles prices
nooooooooooooooooo thank you.
If I wanted wireless, what's stopping me from just plugging in a 50 dollar 1tb external hard drive into my router?
Part of my Win10 test fleet is first generation Atoms... Yeah, netbooks and netbook cpus in desktop cases. They're flying on clean W10 installs.
USB2.0 will get ~30 MegaBytes per second. Not sure I'd call that a bottleneck, and you can't get 30Meg/sec over 802.11g Wifi (7meg/sec at best). If your router supports USB hard drives, I'd go that way. But you usually pay extra for those, which might mitigate the difference in cost of buying a NAS.
The core difference is that a home-NAS provides the firmware (basically, Operating System), while a router which supports USB storage is the one being the firmware. I don't follow these closely, but it's possible the router management of hte device might be more of a marketing gimmick than a well thought-out and thoroughly tested feature. Check reviews for people actually using that option.
And for large file transfers, you might still want to hardwire connect your device to the router and let it sit for a bit. One drop in the wifi signal and you're stuck with a partial transfer unless you use tools which allow you to resume where you left off.
nedirtriders.com
By 30Meg/sec I mean MegaBYTES not MegaBITS. 30 Meg/sec = 240mbps. You're talking 300mbps 802.11n speeds, which is more like 37megaBYTES per second. Yes, it's confusing and I spend way too much mental effort trying to make sure I don't mix the two. And even if you have an N router, and an N device, 300mbps is the ideal speed, but probably not the actual result. And we haven't even gotten to device write-speeds yetJust because your SATA bus can carry whatever gbits a second doesn't mean you're using that.
Edit, I've been talking USB2.0 speeds, but 3.0's getting common enough that it might be more relevant here. While real world results vary its safe to say bare minimum of double the speed of 2.0 and probably much higher than that.
nedirtriders.com
The average user who will see no performance improvement from what they do on a 30Mbps connection.
Techno-envy. Most of my friends who don't work in the industry have it. "I need a new router" -why? "Cause AC is out and my internet/wifi is slow" -How fast is your ISP connection? "25Mbps. I need a new router. B/G/N is too slow" -facepalm
Unless you are doing huge file transfers constantly at home, why bother with all the extra speed you won't use? Hell, streaming 1080p at a typical x264 compression is still only 10Mbps.
Derp. That's my bad. I frequently mix the two as is apparent here.
I fully agree, but doesn't that compound when multiple devices are doing the same thing? "i.e., downloading huge files, streaming video, etc."?
That being said, I wasn't saying that USB bottleneck was my reason to not use a NAS or other like device. I was simply stating the usual response people give when questions of that type are asked. As I said in my original post. I, nor anyone else here, should notice the speed difference in NAS vs USB hard drive attached to router. Which coincides with what you guys are saying.
I updated my 8.1 netbook and the wife's 7 laptop both to 10 Pro 64-bit. OS runs faster on both. I don't see a real difference from 8.1, except that in place of the whole touch screen thing, they moved the useless stock apps into the start menu. It has a wannabe Siri, which we have already disabled.
