Pics available for everything I just don't feel like posting them right now.
For Mille/tuono:
'03 Throttle bodies BARE This is the newer casting that can be bored out to 57mm. These tb's DO NOT include the following parts as they were scavenged for another tb set: injectors, tps, throttle linkage, injectors covers, injector gaskets, fuel pressure regulator.
$75
Rear sprocket carrier with steel 42tooth sprocket and spacers(about 30k)
$50
Swingarm, powder coated metallic gray over black. There is some rubbing behind both foot guards that has worn through the gray topcoat. Also some scratches (heavy on the right side) by the lift spools. Comes with spools, chain guards, chain guide, and reasonably well maintained DID chain. Shock link bearings and seals were replaced 4k ago. Pivot bearings and seals are original and in good condition. (30k on swingarm, 4k on chain)
$250 or $200 w/o chain
Sachs rear shock. Sprung for 220lb rider. Was rebuilt 4k ago (30k shock, 4k spring)
$125
Stock rear spring (30k)
$25
Stock plastic hugger (30k)
$25
Right side inner air duct. missing a chunk at the rear near the frame opening. Otherwise good condition. Comes with screen and plastic wire clip (30k)
$10
Chain adjuster blocks (30k)
$10
Stock exhaust can. decent shape, some scratches, no dents. pics available on request (30k)
$25
For Falco:
Swingarm. very good condition. ships with chain gaurds etc. included.
$100
For Futura:
Sachs rear shock. hydraulic preload adjustment. DOES NOT include linkages.
$75
Front brake rotors. Appear to be in good condition. I have not checked them for runout but they look straight.
$50 pair
