It is flawless, sold one today for 170 looking to get around 150 for it to fund its replacement.
430ex info
* Replaces the Canon Speedlite 420EX Flash
* Automatic selection of camera white-balance settings and auto-adjustment of zoom flash position to match camera's sensor size
* Flash head zoom covers the range 24mm to 105mm; integrated diffusion panel allows extends coverage to 14mm
* Compatible with distance-linked E-TTL II system; supports other EOS cameras that do not support E-TTL II, when required
* Flash head moves up from 0 to 90 degrees, left from 0 to 180 degrees, and right from 0 to 90 degrees
Dibs. Will send PM after I talk to the hub by
