Results 1 to 18 of 18
1gen SV Parts Best Offers.. & Suzuki Track pastics CHEAP!
    Pepperell, MA
    So this is the revised list of what is left of the bike. Best offers considered as I would like this gone!
    Everything is available until I mark it off as SOLD.
    If it's not listed here, I have already sold it, or do not have it available.
    Frame with a clean title $300
    Swing arm assembly with axel bolt and frame bolt, and wheel adjustment assembly. $75
    Front cyclender head assembly without cover. $100
    Entire front assembly - Forks with Tripple tree assembly axel. For "S" model $250
    Coolant Resivour Tank with cap and mounting hardware. $15
    Brake side clip on available for $25
    Odometer assembly with 12K showing $100
    Kick stand with switch harness. $40 SOLD
    Windscreen $30
    Lights control assembly with wiring $40 SOLD
    kill switch control housing/Wire $40 SOLD
    Front brake rotors $100 SOLD
    front and rear stock sprockets $50
    Front brake calipers with pads and brake lines for the pair. $100 SOLD
    Rear brake caliper with brake line/ reservoir $45
    Headlights one piece of housing/mounting tab broken but repairable and stays very secure when used in front cowl assembly. Lights are 100% functional. $35
    Front flush mount directionals $10 SOLD
    Transmission internals (Gearing, all in very good shape, motor only had 12K on it) $50 SOLD
    COIL ASSY,IGNIT $45
    RECTIFIER ASSY $75
    RELAY ASSY,STARTER $40 SOLD
    STATOR ASSY $75
    Cams $50 - I was informed by a member here exactly what cams I have.
    Seems the upgrade was done to my 2nd gen motor!
    So what I have is.
    99-02 SV650
    "B" -EXF. (Exhaust front)
    "D"-EXR. (exhaust rear)
    03+ SV650
    Qty of 2 "J"-EXR (Exhaust Rear)
    Throttle cables $35 SOLD
    Directional relay $10
    White acerbix aftermarket streetfighter light assembly that is 100% functional and good condition. $25 SOLD
    Evap system $15
    Starter clutch $20 Shipped
    www.tailofthedragon.com
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: 1gen SV Parts Best Offers.. & Suzuki Track pastics CHEAP!
    can you tell me what wire colors ? Maybe a pick sent to sheppo<sixone> @ gmail dot com
    Posted by Jane in BoxChat
    Senior Member SCRLT01's Avatar
    Oct 2010
    Westford, MA
    Pm sent....
    --Jesse
    2001 SV650s
    Pepperell, MA
    Sheppo, I will email you a picture tomorrow.
    Jesse I responded to your PM.
    Mike
    twisted gixxer frenchy21's Avatar
    Aug 2010
    east providence,rhode island
    is the bodywork for an 06 gixxer 600?
    Pepperell, MA
    I worked out an arraingement with the buyer of the plastics, he agreed to pay more to help cover shipping costs!
    These are TL race plastics
    Pepperell, MA
    UPDATES: This is what remains, Prices reduced to move.
    Local pick up preffered for Frame, but if your willing to pay the bulk charge for shipping then I will do it.
    Prices do not include shipping costs otherwise.
    Front cyclinder head assembly without cover. $70
    Brake side clip on available for $20
    Odometer assembly with 12K showing $75
    "S" Front cowl/Side cowling W/Flush mount directionals, sold as set $100 SOLD
    Fairing stay assembly $50
    Kick stand with switch harness. $25
    Winscreen $25 (One lower tab broken, but screen stay in place snug without movement, light scratches on screen)
    Front brake calipers with pads and brake lines for the pair. $75
    Rear brake caliper with brake line $25
    Headlights $35 (Damaged, lens and internals are good)
    transmission / gear box / main shaft $45
    RECTIFIER ASSY $75
    Evap system $15
    STATOR ASSY $75
    STARTER STARTING MOTOR $20
    Starter Relay Solenoid $20
    AIR VALVE SWITCH $15
    Horn w/ Bracket $10
    THERMASTATE $15
    OVER FLOW TANK $15
    Throttle cables $35
    Passenger pegs $75 for the pair
    CYLINDER HEAD BOLTS FRONT & Rear $15
    IDLE AJUSTER PLATE $5
    Rear Caliper Mount Bracket Strut Bar $10
    White acerbix aftermarket streetfighter light assembly, 100% functional and good condition. $25Cams $50 - I was informed by a member here exactly what cams I have.
    So what I have is.
    99-02 SV650
    03+ SV650
    Pepperell, MA
    Bump..
    Added a few parts I found, also lowered some prices.
    Pepperell, MA
    Bike is completely torn down ready to find a new bike to be a part of! Any reasonable offers will most likely be taken.
    1gen SV Parts Best Offers..  &amp; Suzuki Track pastics CHEAP!-img_20130412_141516_976_zps48557283-jpg
    1gen SV Parts Best Offers..  &amp; Suzuki Track pastics CHEAP!-img_20130412_141711_079_zpsc4948d48-jpg
    1gen SV Parts Best Offers..  &amp; Suzuki Track pastics CHEAP!-img_20130412_141644_484_zps561d2a1d-jpg
    1gen SV Parts Best Offers..  &amp; Suzuki Track pastics CHEAP!-img_20130412_141530_841_zps20266731-jpg
    1gen SV Parts Best Offers..  &amp; Suzuki Track pastics CHEAP!-img_20130412_141541_132_zps28177b84-jpg
    1gen SV Parts Best Offers..  &amp; Suzuki Track pastics CHEAP!-img_20130412_141549_346_zps4d8cdbe7-jpg
    Pepperell, MA
    Bumped,
    Make offers, want these parts gone!
    Member THE STUFF 187's Avatar
    SWANSEA MA
    I need speedo, race bodywork & gas tank asap.
    Adrenaline Cycle
    Swansea,MA
    Dyno Jet Tuning Center
    Apparel
    Fabrication
    Powder Coating
    Paint
    Service
    Engine service
    Race Bike Prep
    Used OEM Parts
    Track bike rentals
    ADRENALINECYCLEINC.COM
    Like us on Facebook
    [IMG]http://www.facebook.com/AdrenalineCycle1?ref=hl
    Pepperell, MA
    I have the Speedo from the 2002 with wiring which tie into the Main Harness.
    I have a few tail sections I can let one go, the rest are part of the package deal with the 01 SV I am selling.
    Did you find the forks/frame already? Title is good/clean.
    I do not have a tank.
    Re: 1gen SV Parts Best Offers.. &amp; Suzuki Track pastics CHEAP!
    It might help if you cleaned up the first post to cut out the stuff already sold. I know you marked it sold.. but I'm slow and find it confusing.
    Pepperell, MA
    Bump, Any Best offers will be considered
    SWANSEA MA
    Do you know if speedo will work on a 2003? How much for front end = forks,trees,calipers, front rotor? If a good price I can pick stuff up on my way home from Loudon today after 5pm when I leave
    Adrenaline Cycle
    Swansea,MA
    Apparel
    Fabrication
    Powder Coating
    Paint
    Service
    Engine service
    Race Bike Prep
    Used OEM Parts
    Track bike rentals
    Like us on Facebook
    Pepperell, MA
    The stuff 187
    I sent you a PM.
    Call or text me.
    I am home.
    We'll work out a deal we both can live with.
    Pepperell, MA
    HUMP DAY BUMP!
    Pepperell, MA
    Bump... First page list updated
  1. Cheap imported bike parts for a track beater
    By TheIglu in forum General Bike Related
    Last Post: 10-24-19, 06:54 PM
  2. For Sale - Parts & Tools | SV650 assorted parts for 1st & 2nd gen. Best offers.
    Last Post: 03-16-14, 08:32 PM
  3. Needed: Left rearset 1Gen SV650
    By Kitt in forum For Sale
    Last Post: 01-30-09, 06:32 PM
