I've moved on from my TL1000R to an Aprilia Tuono and I'm passing her along to others.
Bike history:
2000 Suzuki TL1000R
12,478 miles
2nd owner, clean title
The bike has been low sided twice(once on each side) with rash damage to both sides of stock fairings that is shown in pictures. Both times the bike slid to a stop and did not hit any objects during the slides.
The bike has two setups, track and street.
Track:
Sharkskinz all around with double bubble windscreen
Graves fairing stay
Custom subframe/carbon fiber undertray
Road:
Stock fairings with double bubble windscreen
Stock fairing stay
Stock subframe
Modded undertray
Mods/Upgrades to bike:
M4 Full SS with Titanium cans
TRE mod(uses the unrestricted 6th gear fuel map in all gears for more power),
hermit dragon airbox
custom airfilter(with extra new filter)
520 chain conversion
pair value removed covered with racetech blockoff plates
Lindemann Engineering front forks with racetech springs (2 sets of springs will work for riders from 150-200 lbs suited)
bitubo rear shock (fully adjustable)
bitubo steering damper (click type)
Power Command 3 with custom map (documentation and map files included)
cutsom air/oil separator
ground mod (more power to spark plugs)
sparrko-mod (more power to spark plugs)
brand new(under 500 miles) braketech rotors and Ferodo pads
custom rearsets
full sharkshinz and full stock fairings
TLS Clutch cable conversion(mechanical clutch instead of hydraulic)
Fan Mod switch(override switch for cooling fans)
custom wiring harness(reduced resistance for increased power and ability to run smaller power)
cigarette lighter adapter
ET79 tank camera mount
iridium plugs
custom undertray
no-cut frame sliders by Smoken
LED turn signals
engine ice coolant
Carbon Fiber rear hugger
graves billet clutch cover
clear rear lens
LED rear bulbs
perdo's GPI(light bar to indicate gear you are in)
extra long bar end sliders
custom paint
Double Bubble Windscreens on all both street and racing fairings
extra bright 100W bulbs
almost new front and rear rubber(under 200 miles)
Complete Repair Manual (hardcopy and pdf)
Stock pipes with custom adapters to run on M4 header for passing DOT inspection
and more I forgot about
Ton of extras like:
Multiple tank mounts
extra frame sliders
EBC ProLite Turbo Rotors with HH+ pads
Wiring harness
ECU
stock airbox with air filter
tons of small hardware bits
extra custom paint plus color code
2-3 boxes of parts
Maintenance:
Oil/Filter change every 1500 miles/season with Rotella T Synthetic
Engine case has never been opened
Values checked 500 miles ago and are well within spec.
I've put a ton of love and cash($5000+) into this bike but as she has been down I'm going to let her go for cheap.
$3000 Firm gets EVERYTHING I have with the bike this includes all items listed above and everything else that I forgot about.
I've attached all the pictures I have on hand. I will be adding more pictures of the race fairings. The race fairings color is identical to the stock fairings. The color is a custom hot rod yellow that is brighter than the stock yellow. Please ask for more if you would like to see any extra.
Bike is located in East Hartford, CT.
I would be willing to ship the bike but the buyer will pay for all costs and handle all arrangements.
2004 Suzuki GSX-R 600 Beater
2004 Suzuki GSX-R 750 Track Bike
2007 Aprilia Tuono 1000 R
I still miss my old TLR. Good luck with the sale
thank you. Yeah the TL is an awesome bike. It is one of the few bikes I've owned that really had character to it.
thinking of getting this bike. before I say I do, does anyone have any reason I should not?
speak now or forever hold your peace.![]()
I ride a custom fighter!
Zip Tie Alley Racing #444
Signature edit by Tricky mike
The only reason I could think of is you'd probably hack it to bits and turn it into some sort of zany streetfighter concoction. But I get it, it's your thing. So do it already, there's not time like right now. Enjoy it, have fun.
I finally sat down today and went through everything extra that is being sold with the bike.
Here is the complete list with pictures of the lot:
Sharkskinz lower painted yellow with dzus fasteners
Sharkskinz upper painted yellow with dzus fasteners
Sharkskinz upper painted yellow with dzus fasteners (cracked)
Sharkskinz rear painted yellow
Stock tail hump painted yellow (locking piece missing)
Custom undertray fairing painted yellow
Custom Carbon fiber rear hugger/chain guard
Stock Black/Gray rear fairing
Stock windscreen
Custom subframe/undertray
Custom seat pan for sharkskinz tail
Graves Fairing Stay for Sharkskinz upper fairing
Lockhart Phillips tank bra
stock airbox/filter/frame mounts
stock shock, linkage, rotary dampener
stock cans with custom adapter for M4 header
racetech spinrgs/spacers
stock springs/seals
EBC Pro-lite rotors with EBC HH+ pads
stock rotors with GALFER pads
stock 530 chain and sprocket set
stock steering dampener
custom camera tank mount(2x)
powerstands mantis tank camera mount
Spares:
spare stock starter
spare radiator/screen/hoses
spare stock brakeline
M4 Full header
spare starter
spare wiring harness
spare Frame sliders
spare bar ends
spare riding foopegs
spare passenger footpegs
spare stock footpegs
spare headlamp bulbs(3x)
spare rectifier
spare stator
spare mass air flow sensor
spare exhaust gasket
spare NGK CR9EIX Iridium spark plugs (2x)
spare custom paint
spare air filter
spare oil filters
many hardware bolts/nuts/brackets/wires/etc...
Please ask for more detailed pictures of anything on the list or angles of the bike.
Free bump as I had an 03' with M4's.
Fun bike but not for what I wanted it to do for me.
-John
"It's more fun to ride a slow bike fast,.. than to ride a fast bike slow."
07 Husky SM510R
Do it! I have a 2000 too (the faster white/blue) with similar mods (minus the suspension) and I can tell you in all honesty that I'll most likely NEVER get rid of it. To each their own, but this is one of my most favorite bikes of all time - it's easily in my top 5. Mine'll be one of those bikes that'll most likely still be in my possession 20 years from now. Wunna those bikes people'll see in my garage and won't believe I have 'wunna those'...
Damn! Look at all those spares!
SOLD!!!!![]()
A new for sale ad of the leftovers will be added soon![]()
Pleasure meeting ya Wedge! We'll have to get together and ride the bikes when I get her all finished up!
traded the 929 for it, and was very happy to see mr.wedge already had a naked bike in his garage!
Nice meeting you customerfighter. Hell yeah, you and I will have to meet up by your area this spring/summer and ride. I should have the 929 registered and on the road in 2-3 weeks. My better half and I took her out for a spin around the block last night(she just kept her legs away from the chain/wheel and was all set) and man oh man is this bike fun.Even with the thousands of stop signs, lol
hahah. yes, there are indeed a lot of stop signs in your area lol. glad you like the bike. Think i'm going to toss a plate on the tiller and take it for a quick ride before i start tearing it all apart![]()
BUMP...anyone interested in this bike???
I never got around to turning it into the project I wanted...and could use the money and space much more than another bike at this point.
I stripped it of the fairings, but I still have them and all the other goodies. All reasonable offers considered.
ah still miss my ol TLR, great bikes
ahhhhh, my old bike.Such a great bike, definitely one of my all-time favorites. This is a great machine for anyone interested.
interested in trades as well.
I am parting this out, if anyone is interested in anything shoot me a pm and we can discuss pricing, thanks!
Corey
Are any of the following still available?
