Results 1 to 4 of 4
2000 Trans AM Vert Part-out
    Lifer obsolete's Avatar
    Norf Sho
    This is a full part out of my NBM 2000 Trans Am convertible. I am posting this listing in multiple locations so all dibs/requests need to go through my email: obsolete346@yahoo.com. Anything that gets posted in the thread or is pm’d will probably get missed so I apologize in advance but I need to keep some organization here.
    I would like to keep the sales somewhat local (eastern MA), especially for the big stuff. You can surely ask if I will ship and either I will say no, you will pay for all the shipping costs or we can arrange a drop off.
    All prices are obo and I am open to trades and package deals. I want to clean out my garage so let’s make some deals! $12,000 and take the whole thing.
    Built Engine and Transmission: $7,000
    I am selling this as a full swap. It is a complete LS1 and 4L65E with computer, engine harness, torque converter and drive shaft. The engine was assembled ran a few times and then taken down to short block to remove it from the car. It has sat for a couple years and there for will need to be opened up, cleaned and reassembled. It will need a re-hone. The tranny has less than 10k miles on a rebuild and a transgo stage 3 shift kit.
    Parts:
    Diamond forged 11:1 Pistons
    Diamond Pro Select Rings
    Diamond Tool Steel Wrist Pins
    Eagle H-Beam Forged rods
    Thunder Racing Chromoly Push Rods
    Coyles Double Adjustable roller timing chain set
    Ferra gold Dual Springs
    Ferra Titanium Retainers
    Ferra spring locator set
    ARP Head and Main Studs
    Heads Ported
    LS6 Intake
    G5X2 Cam
    Comp Lifters
    APE Ported LS6 Oil Pump
    ASP Under drive balancer
    Hypertech 160 Thermo
    Nitrous Systems: They will need some wiring and switches and few other things as noted.
    Wet: $1000
    10 lbs. bottle
    Zed Remote opener
    3 Relays
    NX Bottle warmer with sensor
    Hawk Window switch
    NX Fuel / Nitrous / Purge Solenoids
    FPSS
    Brackets
    Jets
    Electronic Nitrous Pressure Switch
    Fittings
    Hardware missing (Feed line and nozzle)
    Dry: $500
    SLP Lid drilled and 5177 fittings installed
    Relay
    5177 Solenoids
    Purge Solenoid
    Feed line
    Brackets
    FPSS
    Fittings
    MAFT
    MSD Window Switch
    15lbs. bottle
    Heater (will need sensor)
    Jets for 50 / 75 / 100
    Sphon torque arm and drive shaft loop for convertibles: $300
    BMR Bolt in 10 Bolt LCA relocation Brackets: $60
    Panhard bar and LCA’s (not pictured): $300
    BMR double adjustable / bushing ends / hammer finish
    Weld Drag Lights and tires: $600
    Morosso DS2 Front runners
    Slicks(one is torn and useless)
    MT Drag Radials
    B&M Pro Stick Ratchet Shifter: $150
    Wolfe 6 point Chromoly Jig notched roll bar: $500
    Moser 12 Bolt 33 spline / spool / girdle cover: $1800
    The housing and axle have some surface rust and will need to be cleaned up a bit.
    Holly Blue Pump: $80
    Line Lock: $80
    Lid: $80
    Jaz 1 Gallon Cell: $80
    Brake Adjuster: $30
    Earl’s Hyper Firm Stainless Lines: $80
    Bellows: $30
    Fuel System: $800
    Bosch Pump
    PowerFlow Regulator
    32 pound Injectors
    Flowtech Headers: $150
    Sport Comp Electric Gauges and dual pod: $280
    2 1/16 Oil Pressure
    2 1/16 Water Temp
    Fuel Pressure
    -Alex
    Norf Sho
    Re: 2000 Trans AM Vert Part-out
    Chassis: $2000
    The car was being built to be a race car/street car so there has been a bunch of lightening, rad support, inner fenders, foam and bumper mounts are gone. Also the HVAC, carpet and seats are gone. Most everything else is there. It has BMR k member and will have the stock 5 spoke rims and 10 bolt with 3:32 gears and a stud girdle cover. This is a tan top convertible with a clean title.
    -Alex
    Norf Sho
    Bump
    -Alex
    Norf Sho
    Blumpkin
    -Alex
  1. Sidi Vert 2 Size 41 Boots
    By LuvDog in forum One Man's Garbage...
    Last Post: 12-16-21, 03:34 PM
  2. Replies: 0
    Last Post: 08-10-10, 06:42 PM
  3. 2000 R1 part-out
    By Kitt in forum For Sale
    Last Post: 10-14-09, 11:47 PM
