Results 1 to 6 of 6
2001 Suzuki Turbo hayabusa
    Senior Member Big Draggo's Avatar
    May 2003
    Westminster, MA
    2001 Suzuki Hayaboosta
    https://youtu.be/oM0b_l2AMF4?si=Yl2OU5iN-bbuajQm
    Featured in Super Streetbike Magazine
    Built and tuned by the late great Dave “DaveO” Owens from Fall River MA
    Over 425HP-260ft/lbs at 28PSI of boost on C16 race fuel
    Engine and Transmission
    · JE Turbo Pistons Forged 81mm 8.5:1
    · Falicon Connecting Rods
    · .080 cylinder base plate
    · Heavy Duty Valve Springs, guides and seals
    · APE Heavy Duty Cylinder Studs
    · Adjustable Cam Sprocket
    · MTC Multistage Lock up Clutch and Billet Hub
    · Undercut racing transmission and heavy duty output shaft
    Velocity Racing Stage 2 Street/Track Turbo System
    · Custom Dual Ball Bearing GT-25 Turbo with dump pipe
    · Stainless header and Polished Intake Plenum
    · Piggyback Secondary Fuel Injectors and Fuel Rail
    · Supplemental Onboard Computer
    · 50mm Tial Wastegate
    · HKS Sequential Blow Off Valve
    · Aqua Mist Methanol Injection System
    · TurboXS Dual Stage Boost Controller with arming switch
    · Blitz Turbo timer with boost memory
    Chassis
    · JMC adjustable 8”-14” over Mega Top and Bottom Braced Swingarm
    · Adjustable Lowing Links
    · Autometer boost and fuel pressure gauge
    · Raptor Performance LED shift light
    · Custom Torbin cut Seat
    · Vortex billet rearsets
    · 200mm HPX tire
    · Pringle tether kill switch and air shifter control
    · MPS Electric air shifter with onboard compressor and Spencer Cycle bracket
    · Billet adjustable kick stand
    · Clear Alternative signals
    · MTC custom clutch cover
    · EK 530ZVX Drive Chain and 18T 40T sprockets
    · Trac Dynamics Triple Clamp
    · Goodridge Stainless Steel braided brake and fuel lines
    Paint: John Clouiter owner Splat Graphics. House of Kolor™ Brandywine candy
    New battery
    Oil and fluids
    Bosch Fuel pump, fuel filter injector fitting
    Over 50K$ invested, Cash only, no trades no tire kickers, no test riders as is.
    https://www.facebook.com/share/1C8sUEKRwk/
    Yellow light, green light, heart stands still...
    Lifer OneCheekRider's Avatar
    Aug 2012
    LA
    Re: 2001 Suzuki Turbo hayabusa
    is this a good first bike?
    10 Not allowed! Not allowed!
    Lifer union's Avatar
    Blackstone, MA
    One of the best.
    James
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    Only 14,000 for all that ?
    Great bike and deal .
    If I didn’t already own the Dragonbike ,I would seriously consider that beauty .
    You a member at Hayabusa.org ?
    The for sale bikes move pretty quick there .
    TIMMYDUCK
    Oct 2020
    Chelmsford, MA
    this thing shouldn't be sold to anyone born before its manufacture date
    Lifer jimmycapp's Avatar
    Oct 2008
    NW CT
    First and last
