**** BIKE IS NOW SOLD ****, as of Sep. 26
2001 Suzuki SV650 Red
38,671 miles
Clear Massachusetts title in-hand
VIN JS1VP52A512103998
Asking price, $2000 $1500, note that some items are being parted out, CA April 18
New price $1400 April 19
Newer price $1200 May 3
Newest price $900 Sep 20
Modifications
- Penske 8981 Rear Shock - fresh rebuild (0 miles) Not included in sale, being sold separately. Bike will have a OEM shock installed - CA, April 18
- Gold valve emulators, Stiffer fork Springs (I think 0.90kg/mm), preload adjusters for front springs.
- Forks have a fresh rebuild (0 miles) by GMD computrack, including a straightening of one tube (had a very slight bend)
- SS braided brake lines Front and rear
- Micron headers, Scorpion muffler
- Short-turn throttle tube (R6 type)
- Quick release seat pins
- Shaved seat
- Woodcraft clipons, rear sets and clutch cover
- Frame sliders
- Swingarm spools
- Daytona digital temperature gauge
- 520 size chain conversion
- Woodcraft toe guard for chain
Potential concern
- There is no tachometer, it broke off about 8 years ago.
- One of the engine mounts is slightly cracked, but the bolt still tightens and it has ran without issue for several race weekends.
- Rear subframe is not straight and the rear seat does not latch.
- Bodywork is 3/10, tank is dented but holds fuel fine
- Water was left in engine over winter in an unheated garage, the engine will come up to temperature, the fan kicks on and it cools back down as it usually does. There does not appear to be any mixing between water and engine oil. I think it's OK but it's hard to guarantee. UPDATE - I can offer a 60 day partial refund if the engine turns out to be damaged due to water freezing. It would bring the effective purchase price down to $1500 ($500 back). You'd just have to document the damage via pictures UPDATE 2, this will be a $300 refund now that the price is lowered, CA April 18
- The engine burns about 1quart of oil for every 500 miles on the track. It still makes good power and in the past has run ~12.4s @ 106mph 1/4 mile times (with a 190lb rider)
- A cracked weld near the rear of the frame was repaired in 2008 by a professional weldor, it has not had any further issue.
General notes
The bike has done about a dozen track days and one season of racing in the Loudon road racing series. It's also been cross country and generally enjoyed. Although it has a few scrapes, this bike has never let me down.
Extras (these are all included in the sale)
Foot Controls
- Complete right Woodcraft rear set assembly
- OEM Rearsets, with pegs and levers
- Shift rods
- Shifter arm
- (3) Woodcraft shifters, used
- Woodcraft brake pedal, new
- Woodcraft left and right rear set brackets, on each, well used
Hand Controls
- Woodcraft left and right clip ons, with (4) spare tubes (all new) Not included in sale, being sold separately - CA, April 18
- (2) OEM left grips, new and used
- OEM and Yamaha R6 throttle tube (short turn)
- (3) OEM clutch levers, new and used
- OEM throttle cable set (Shorter SV650S type, for use with clip-ons)
- Clutch perch, new
- Brake lever, well used
- OEM handlebar risers
Others
- Goodridge SS braided front brake lines, used
- Various brake bolts and hardware
- Rear brake pads, new
- Left and right rear plastic body panels, helios red (from '99 and '00 model year) Great condition!
- Rear subframe, used and not 100% straight, but better than current one installed
- OEM clutch cover, used
- Nate's type frame sliders, used with life remaining
- Vortex brand frame slider pucks, delrin and aluminum (new and used)
- Jet kit, for carbs
- OEM Exhaust, cut for slip-on
- Muzzy slip-on exhaust
- Fork springs, 0.85 kg/mm springs (2) and stock springs (4), stock spacers too
- Fork seals and bushings (maybe new)
- 48tooth 520 rear sprocket, anodized aluminum with little use
- Michelin Pilot power sport tires, used with 60% tread remaining. 120/60 front and 160/60 rear
- Empty passenger seat pan, no foam or covering
- Front fender extender
- Passenger handle
- Headlight, some damage
- Brackets to mount headlight with clip-ons (modified OEM brackets)
- OEM mirror
- Horns, blinkers, reflectors and taillight
- OEM toolkit (mostly complete)
- Belly pan, race legal type, needs repair for cracks.
- Air filters (2), new, OEM type
- Oil Filters (4), new, OEM type
- Suzuki factory service manual
- Many receipts
- Maintenance records
Bump for a bike that has a heart of gold and looks like hell.
If anyone has any concerns about the engine being toast I can offer a refund good for 60 days to bring the effective purchase price down to $1500 if it looks like water froze and damaged it. I think it's ok but I would be hesitant to purchase it too for that reason.
See a for sale listing on craigslist here, http://westernmass.craigslist.org/mcy/3736080620.html
That is one ugly mofo.....I love it!
Bump, still for sale
If you decide to part this bike out please let me know i am interested in purchasing that Penske Shock off of you.
Bump for a reduced price and deleting a couple of the goodies (Penske shock and spare clip-ons)
Roland, you've got first dibs on the shock. I responded to your craigslist email yesterday with a price.
Know how much of these aftermarket parts are compatible with the gen 2 SV? I might be interested in taking the bike for the upgraded parts.
I lowered the price a bit, $1400.
Still for sale!![]()
bummpity bump bump bump
Still for sale!
Just lowered the price to $1200!
Vroom vroom.
Someone here must love the ugly bikes.
Still for sale!
TTT with a lower price, $900!
I'll be calling you tomorrow about this.
SOLD!
