Results 1 to 20 of 20
2003 CBR600RR Part Out On The Cheap!
    Ambition Outweighs Talent strgt's Avatar
    Jun 2009
    Im posting this here first in case anybody wants anything, I can bring it to Loudon with me labor day weekend. Motor available shortly. Shipping Extra. May have other small misc parts available. Heres the list:
    Ohlins Triple Clicker Shock, hydraulic preload adjuster, set up for 170lb rider, 628lb spring, freshened in beginning of 2010 season by Thermosman, $550
    Straight Upgraded Forks, GP Suspensions compression valves, reworked rebound valves, .95kg Springs, valved by Computrack Boston, 170lb rider, $300
    Ohlins 20mm Supersport Kit, reworked by Thermosman Suspensions, good for 230lb rider, will fit most 20mm cartridges in modern sportbikes, $200
    Traxxion Dynamics Omni Fork Springs, 1.0kg for CBR600RR, may fit other forks, $50
    Scotts Damper, rashed but works fine, rebuilt end of 2009 season by Scotts, $150
    Scotts Damper Mount, for 03/04 600rr, $50
    PENDING SALEBrand new 05/06 600rr E-racings Upper, Lower, Tank cover, and (2) fenders, also fits 03/04, $200
    Aftermarket 03-06 600rr Vortex Fairing Stay, used for one race, never crashed, still has stickers on it, $125
    Full Hindle Exhaust, Titanium can, few small dents, and dented tip but didn’t seem to affect performance, $250
    Dynojet PCIII USB, 05/06 600rr, works with 03/06 600rr (just need to load 05/06 maps), $150
    Woodcraft Clip-ons, rashed but work fine, w/ new bars $50
    Pitbull Trailer Restraint Pins, good condition $50
    HRC 1/6 quick turn throttle tube, $25
    PENDING SALEStainless Steel Lines (Galfer I think) $30
    PENDING SALEWoodcraft Frame Slider Bases, $20
    Calipers w/ Vesrah RJL Pads, pads have 4 races and one track day, $75
    Front Wheel w/stock rotors, straight, gloss black, $125
    Front Wheel w/stock rotors, straight, semi-gloss black, $125
    Front wheel spacers, only had one set so I am selling separately, $5
    Rear Wheel w/ lightened rotor, straight, semi-gloss black, $125
    Rear wheel w/ stock rotor, straight, gloss black, $120
    Cush Drive & Spacers to go with one rim, $10
    Straight Axels, $10 each
    Subframe, may be very slightly tweaked, not noticeable if it is, $40
    ECU $50
    Frame w/ clean title, .4 degrees out of alignment according to computrack, can be straightened, $400
    Tweaked triple trees, can be straightened, $40
    Gas Tank, two small dents, Vortex Keyless Gas Cap, $100
    Main Harness, modified for race, works fine, $40
    07/08 CBR600RR throttle housing, (used for HRC Throttle), good shape, $25
    07/08 CBR 600rr kill switch, modified for 03-06 600rr harness to work with throttle housing, good shape, $20
    Throttle cables, small kink at mount, works fine, $10
    Clutch perch and Cable, small chips from pea gravel in T6 $10
    PENDING SALEWoodcraft Rearsets, pretty beat up but they work, good for spare parts also, $65
    Lockset, with gas cap, and key, $100
    PENDING SALEStock Seat, excellent condition $20
    Stock exhaust, excellent condition $40
    All prices OBO! Most of these parts are still on the bike, and will be taken off the night of payment and shipped the next day. Ill be listing all this stuff on the WERA forum and 600rr.net shortly so let me know if your interested in anything. Pics are available by request of pretty much everything.
    www.streetandcomp.com
    LRRS/CCS/WERA Am. #290
    NESBA Adv. #290
    Just Registered Doc's Avatar
    Jericho, VT
    Re: 2003 CBR600RR Part Out On The Cheap!
    How much for the whole front end? Wheel, brakes, triples, clipons and forks.
    Wirelessly posted (BlackBerry8530/5.0.0.734 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
    How much for the motor? Pm me pls.
    Jun 2009
    Pm sent to both of you
    NESBA Adv. #290
    Lancaster
    Interested in the ohlins shock, please pm details. Thanks
    Corey
    Tricky, you need some spares?
    LRRS CCS AM#636 blacklightning's Avatar
    Goffstown, NH
    interested in bodywork. pm sent
    LRRS/CCS AM 636
    Lancaster
    Also a picture of the woodcrafts would be good
    Corey
    RSP Racing 535 Io-bot's Avatar
    Apr 2004
    Humm... i might have to hit you up for a few things
    Jun 2009
    Pics of the shock:
    Pics of the rearsets:
    Pics of damper and mount:
    Pics of exhaust:
    NESBA Adv. #290
    Jun 2009
    Quote Originally Posted by Io-bot View Post
    Anything you want, as long as its not going to make you faster.
    NESBA Adv. #290
    Jun 2009
    Added trailer restraint pins
    NESBA Adv. #290
    Great meeting you at the track last race weekend.
    you've got me thinking about a couple of things
    I could use some upgraded suspension, Steel brake lines and maybe a set of wheels???
    Jun 2009
    Nice meeting you as well Gino. You got me wanting a hawk now. Going to keep an eye out for something over winter time. BTW Your 600rr wants you to buy it a new shock, it will thank you
    NESBA Adv. #290
    Lancaster
    i looked on ohlins website and it doesn't seem that that shock will fit 05-06, i could be wrong but ohlins makes a different one for the 05-05 then the 03-04, major bumber, nice shock!
    Corey
    Jun 2009
    It will physically fit, I believe the change was made in the internal valving due to the taller geometry. Thermosman added a little rebound into the damping of the shock to compensate for the fact that I ran the bike 6mm taller in the rear so it should be all set if you just run the shock at the height I have it set at.
    http://www.600rr.net/vb/showthread.p...lins+shock+fit
    NESBA Adv. #290
    PM sent on a couple of items.
    Jun 2009
    TTT, updated list!
    NESBA Adv. #290
    Jun 2009
    Bump last chance before I go to Loudon this weekend. Ill also be at monticello monday, and Jersey the next weekend.
    NESBA Adv. #290
    Jun 2009
    Bump still have these parts available.
    NESBA Adv. #290
  1. Wanted - Parts & Tools | WTB 2003 cbr600rr engine
    By Scottg22 in forum Wanted
    Last Post: 12-17-21, 10:35 AM
  2. For Sale - Parts & Tools | 2007 CBR600RR Part Out (Updated 10/18/16)
    By Rab in forum For Sale
    Last Post: 10-18-16, 02:51 AM
  3. 2003 Honda CBR600RR
    By Jaynnus in forum For Sale
    Last Post: 03-28-13, 09:48 PM
  4. Need to borrow a part foir a CBR600RR
    Last Post: 06-12-08, 11:50 PM
  5. 2003 CBR600RR
    By hammadown in forum For Sale
    Last Post: 08-24-07, 11:58 AM
