Selling my truck but have some things lying around I bought for it.
(2) lower ball joints
(1) upper ball joint
(2) outer tie rods
This is for a 1500 truck, 4wd (if that makes a difference) etc. I'll even let you borrow my ball joint press. I don't know if these will fit newer or older GMs. They are for a 2004 if you want to cross reference.
Long shot and all but $10 per item. This is a steal if you need these parts. I'll give you particulars if interested.
So I still have these. I have also found a few other things that I have available. These were originally purchased for an '04 Avalanche, so I believe they'll fit a 1500 truck, tahoe, yukon, suburban, etc. of similar years. All of these parts are brand new.
Ball joints and tie rods as listed above.
Rear brake dust shield
set of rotors and pads for front brakes, brand new Power Stop
Set of spark plugs, Denso iridium (5.3)
Serpentine belt (5.3)
I just want them out of my garage. You WANT them, bring me a decent 6 pack. You NEED them, come and get them.
My wife has a 2005 Escalade, I'd assume these parts would fit it? Where are you located?
I don't know. Escalades are a bit different, sometimes. The engine in an 05 is probably a 6.0, not sure if the engine related parts would be the same. Maybe cross reference parts to see if they are the same between the Escalade and a standard GM half ton platform.
I'm in north central mass, leominster area north of Worcester.
According to Rock Auto's parts list, all of the parts are the same for my 6.0 Escalade. What brand are the ball joints and tie rod ends?
I think the ball joints are Mevotech and the tie rods I'm pretty sure are Moog.
If you still have these, I’ll take them.
Still have all this stuff. I was just in Mystic this weekend too.
day, evening, weekend? I could meet you closer to a highway and save you bunches of minutes.
