Results 1 to 4 of 4
01 KTM LC4 640
    01 KTM LC4 640
    Selling the motard again. Title is in hand.
    25,6xx miles, 16/40 gearing, Trail Tech Vapor computer, HID headlight, LED running light, Behr factory KTM wheels, integrated LED tail light and fender eliminator.
    New parts:
    -New Pilot Power 3 Tires
    -New Vesrah JL front brake pads
    -New Superlight sprockets
    -New DID 520 chain
    -Rebuilt and rejetted carb
    -New rear wheel bearings
    -New steering stem bearings
    -Rebuilt forks by Hutch motorsports
    -500ish miles on new piston, crank, rod, replated bore
    The bad:
    -Valves sound a little noisy, or a loud auto-decompression system
    -cracked tab on cylinder head which has been repaired with JB Weld (near intake boot, non critical area)
    -needs throttle cables (frayed on carb end)
    Basically it could be as little as a valve adjust, could be a loud auto-decompression system, or it could be a rocker arm roller bearing (cam follower bearing). I'll be taking it to Cliff's soon to have them give it a listen.
    I have a bunch of parts
    -Spare carb
    -Wheel spacers
    -Enduro Engineering speedo eliminator
    I also have a "high flow" head off an 04 KTM SMC that I was planning on installing, along with a full Pro-Circuit exhaust. The bike doesn't need the head, but I figured if it does need the rocker arm bearing, I would upgrade it with the high flow unit. I also have a Pro-Circuit full system for it (header and silencer).
    $2200 for the bike only
    $2800 for the bike, the high flow head, and the exhaust.
    Feb 2012
    Re: 01 KTM LC4 640
    Your sig rofl
    Too many bikes to list
    Mosdt likely drunkd
    Re: 01 KTM LC4 640
    Want a buell?
    Re: 01 KTM LC4 640
    Quote Originally Posted by gtbensley View Post
    Want a buell?
    I've always been tempted by Buells especially the XB lineup. Shoot me a PM.
