• Clean Title, Straight and Sorted SuperBike SV
• GMD built Showa 2001 GSXR 750 forks – aftermarket anti-friction coating, extenders, valving.(9.5kg springs)
• GMD Billet adjustable triple clamps
• Penske Triple adjustable shock (650 lb spring)
• Ohlins linear steering stabilizer
• Brembo 2 Piece Billet GP front brake calipers with Performance Friction pads (Full race not OEM)
• Brembo radial master cylinder (Full race not OEM)
• Powder coated frame and swing arm
• 5.5" Rear GSXR wheel
• Captive Spacer kit front and rear
• Engine
Spears Spec 2MM over Superbike engine, JE Pistons, Magnafluxed, lightning, Shot Peen, Balanced, Full Superbike head work/ Valve Job from Edco etc. Mega Cams. Makes 83-85 hp
• Yoyodyne Slipper Clutch
• 41mm Keihin FCR flatslide carbs
• Full Akrapovich Titanium exhaust
• Pace Superbike radiator – (SV specific )
• Woodcraft clutch cover
• Sharkskinz bodywork in good shape
tank has dents but plenty functional holds fuel no problem
• TransLogic Factory Quickshifter specifically designed for first generation SV’s from Spears.
• GP Tech faring stay
• Lightweight Aluminum subframe
• SPA tachometer with temp and programmable rev light
• Vortex keyless gas cap
• Woodcraft frame sliders, Clip-ons,High rear sets, Hand guard
• Adjustable Folding levers
• Galfer Front Wave rotors
• Drilled rear rotor
• Shorai lightweight battery with Total loss charging system
• MotionPro Quickturn Throttle
•Few different Spares
Rear wheel
Oil cooler for radiator never installed.
Rotors
Rearset parts
Bodywork
Ect.
$3900 OBO
Located in Putnam/ Woodstock area of Connecticut
Email heylewy@hotmail.com, text, call 860-377 five637
EX#75 2012 AM LWSS Champion
2012 AM LWSB Champion
2012 AM LWGP Champion
2012 AM GTL Champion
bump
bump
Would be interested in plastics and steering damper.
Bump
bump
bu
Deposit delivered, bike is sold.
