Honda FG 110 Tiller
MSRP $389
Runs, could use fresh gas $175.
Specifications:
Tiller Type Mini Tilling Width 9" Tine Diameter 8" Engine Honda GX25 Displacement 25cc Air filter semi-dry Fuel capacity 0.60 qt. Transmission Speeds 1 - forward Tine speed @max engine speed 294 rpm Transmission Type worm gear Dry Weight 24.9 lbs. (26.8 lbs. with wheels)
K2 recon riser
161? Good condition, some scratches on top sheet. Bottom good shape.
$125
Burton Hail boots black size 13, 4 runs on them. $75
Burton Boxer boots grey size 12, around 10 runs on them. $50
Gateway 19" widescreen used very little $60
Wirelessly posted (Tilt: HTC-8900/1.2 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.11) UP.Link/6.3.1.20.06.3.1.20.0)
specs on the monitor? res, response, refresh...etc
