Results 1 to 7 of 7
SV650 assorted parts for 1st & 2nd gen. Best offers.
    Pepperell, MA
    If it's not listed here, I do not have it.
    ALL 1st gen SV parts
    ADDITION FINDS In my Garage.
    Gen 1 Side Panels (Midbike-frame/tank cover) $50 for the pair
    01 Aprilia Mille complete lower belly pan, Can be modified to fit Tuono/Falco $150 (No cracks or breaks, just needs to be prepped and painted)
    Chicken Hawk Tire Warmers fit up to 17X180 rear 17X120 front work good. Some tears but always worked well.. $200
    1st Gen SV650 (02) Frame with a clean title $300
    02 SV650 Swing arm assembly with axel bolt and frame bolt, and wheel adjustment assembly. $75
    Gen 1 Belly Pan and Bracket assy. Needs light work/paint No cracks $75"
    "99" SRAD Unpainted Race Tail $50
    2 Front GSXR Front fenders, Suzuki Blue good cond one is a "01"m other is "03" $35 each
    1st gen SV650 Front cylinder head assembly without cover. $60
    Second Gen SV650 (02) Entire front assembly - Forks with Tripple tree assembly axel. For "S" model $200
    Brake side clip on available for $15
    "02 SV650 "Odometer assembly with 12K showing $75
    Winscreen $25 (One lower tab broken, but screen stay in place snug without movement, light scratches on screen)
    Rear brake caliper, Master cylinder, brake light switch/Spring with brake line $50
    Brake side Stock rear set with Master cylinder/ stock brake line/Rear reservoir and Hose. GOOD cond with exception =(Brake pedal slightly bent) $75
    Headlights $25 (Damaged, lens and internals are good)
    RECTIFIER ASSY $75
    RELAY ASSY,STARTER $40
    STATOR ASSY $75
    Fairing stay for custom mounting Race plastics $50
    Starter Relay Solenoid $20
    AIR VALVE SWITCH $15
    Horn w/ Bracket $10
    THERMASTAT $15
    OVER FLOW TANK $15
    CYLINDER HEAD BOLTS FRONT & Rear $15
    IDLE AJUSTER PLATE $5
    Rear Brake Master Cylinder $15
    www.tailofthedragon.com
    Re: SV650 assorted parts for 1st & 2nd gen. Best offers.
    Quote Originally Posted by Half Squid View Post
    Second Gen SV650 (02) Frame with a clean title $300 Second Gen SV650 (02)Swing arm assembly with axel bolt and frame bolt, and wheel adjustment assembly. $75
    Is this a typo? '02 would/should be fist gen, no? Your CL ad has the same error.
    Posting Freak Tas's Avatar
    Sep 2013
    Jaffrey NH
    Have pics of fairing stay? This would be for 2004 650n.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    Pepperell, MA
    Yes NHBUbba is correct these are all Gen 1 parts.. My bad...
    May 2013
    Epsom, NH
    is the fairing stay mount for woodcraft fairings and are gen 1?
    Pepperell, MA
    The Fairing stay is for a gen 1 mount and can be modified to fit whatever you require with a Welder.
    This specific Stay works for Gixxer Fairings and SV race bodywork. I can email or text a few pics or I will upload here shortly.
    May 2013
    Epsom, NH
    I'll take it, PM sent
  1. For Sale - Parts & Tools | 2g sv650 parts
    By theducman in forum For Sale
    Last Post: 09-18-17, 06:40 AM
  2. For Sale - Parts & Tools | Sv650 parts lot
    By ginness72 in forum For Sale
    Last Post: 03-01-17, 12:45 PM
  3. For Sale - Parts & Tools | 2nd Gen SV650 parts
    By Vovchandr in forum For Sale
    Last Post: 08-26-15, 02:26 AM
  4. Replies: 17
    Last Post: 07-08-13, 06:14 PM
  5. Assorted bike parts for sale.
    By desmoducknh in forum For Sale
    Last Post: 04-02-12, 07:39 PM
