1
2003 SV650 Superbike # 109
Motor has a 01 Falicon balanced crank, Falicon rods, 2 mm pistons, 1 mm oversized stainless valves , cams, ported heads, adjustable cam sprockets APE cam chain tensioners, Yoyodyne slipper clutch, PC III USB, Quick shifter. Rebuilt by MARKBILT May 2012 82hp on pump gas.
Chassis is a 2003 with a slavage Ohio title, has Ohlins rear shock, 09 GSXR 750 front end with GP Suspension fork extenders recently reworked for a sv by Linderman Engineering, taped steering stem bearings, Brembo radial master cylinder, R6 front calipers, Brakin Axis front rotors, Vesrah brake pads, lightened rear rotor, Vortex aluminum fairing stay, lightweight aluminum rear subframe, Woodcraft clip-ons, rearsets and frame sliders, 2003 GSXR 1000 Sharkskinz fairing with superbike tail, chassis measured and set up by GMD Computrac NY @ 2008.
Comes with all my SV stuff as follows;
2009 Black clean titled frame
1 stock rear subframe
1 perfect fuel tank
1 GSXR front wheel
1 SV650 front wheel with rotors
2 SV650 rear wheels
Rain tires
3 SV sprocket carriers
3 fuel pumps
2 sets of coils
1 throttle assembly with cables
1 throttle bodies with injectors
1 clutch hub and pressure plate
1 brand new stock clutch fibers & steels
2 new clutch case cover gaskets
2 new clutch cables
2 sets of stock sv front calipers
spare shifter and brake levers
1 Hotbodies 2003 GSXR 1000 upper and lower fairing
1 set of tire warmers
1 XT Ultra lap timer with beacon
some misc other parts.
Located in northern NJ asking $5000.00. normally in Center garage 23
Bump
Willing to sell bike separately without the extras for $3600.00
If you part with your spares, I'm interested in the following;
Tank
1 fuel pump
Front calipers (when you say 2 sets, do you mean 4 calipers or 2/ one each side?
1 pair of Coils
Subframe for me!
Is this bike still available?
Yes it is.
Price reduced to $4500.00 for the entire package.
Sale pending / SOLD
