Local pick in Woburn
New never installed OEM Ducati large kick stand pad.
$35.00 ( plus $5.00 ) for most US states.
Used Speedymoto rear axle slider
SPEEDYMOTO Rear Axle Sliders: 1098 / 1198 / SF / 1199-1299 / MTS1200 / Monster 1200 / Diavel
DESCRIPTION
SpeedyMoto Rear axle sliders are designed to be the best protection for your 1098, 1198, 1199 or Streetfighter or new Multistrada 1200.
SpeedyMoto sliders are made from superior and more expensive HDPE plastic, which slides and absorbs impacts better than any other product on the market. Other materials tend to grip, flip and brake.
Works with a standard rear stand so you can service the bike easily.
Easy installation, only takes minutes.
Anodized aluminum rod and stainless hardware holds both side firmly together and won't corrode!
Kit BIG HUB late 2007 to current 1098, 1198, Streetfighter, Multistrada 1200, 1199
Special Note! *Early 07' 1098's have an axle that measures 42.7mm on both left and right sides. Later models 2007 1/2 and newer have a thicker left side axle with a 40mm ID and the right side is 42.7mm. If you have a 2007 please double check your left side axle before you order.* Important: It will only protect the left side on Diavel!
Used Woodcraft front axle slider
$20 ( plus $5.00 ) for most US states.
One of the slider is worn and you can get the spare from Woodcraft.
www.woodcraft-cfm.com - Ducati8481098119889995911991299DiavelMonster8211200FrontAxleSliderKit
Used GIPRO DS GEAR INDICATOR BY HEALTECH DUCATI / MONSTER 1200S
$80.00 plus $5.00
GIPro DS Gear Indicator by Healtech Ducati / Monster 1200S / 2016 (GPDS-D02-C08)
SKU GPDS-D02-C08-RD
The GIpro-DS from HealTech Electronics is a unique Gear Position Indicator. It is designed for fuel injected motorcycles equipped with Diagnostic System connector.
Due to high demand for the GIpro, Healtech has developed the DS-Series, which is compatible with more motorcycles than the original GIpro.
The GIpro-DS works on different principle than competitive products on the market. It reads the gear position information directly from the ECU, which makes it faster and more reliable than other gear indicators sold today. There are no buttons, no programming wires. The unit is fully automatic.
There's no need to cut and splice wires, and no need to access several connectors. You need to connect ONE plug only under the seat; it can't get any easier than this.
Another unique feature is the size. It is the smallest, most compact gear indicator available, while it has an extra bright, sunlight-viewable display. Just the perfect size. The unit is available in Red, Blue, Green, Yellow, or White display.
The Healtech Gear Indicator is rugged, 100% weatherproof
Used Evotech DUCATI MONSTER 1200 S ENGINE GUARD PROTECTOR 2014+
( My radiator guard required me to trim the corner, since there's a bracket. When you install this, you can't tell from looking at it.
$40.00 plus $10.00 Shipping in the US
Sump Guards | Ducati Monster 1200 S | Evotech Performance
Still have the engine guard and kick pad?
