2002 SV650 Parts bike up for sale. The pricing is lower than any used parts I could find listings for on Ebay. This list I copied and pasted of my posting from SVrider site. NESR members take 10% off the price, buy multiple ite,s and I will work magic with the pricing!
Parts Available:
I have almost an entire 02 SV650 I am parting out.
Everything you see in the picture and more.
Everything is in very good condition.
Does not include shipping cost, I will gladly check a qoute for you and only charge that qouted price. Local pick up or meeting point can be set up if within a reasonable distance.
Only things not available is the motor, brake lever, clutch lever, sub-frame, brake pedal/rear master cyl, & rider peg assemblies.
Everything is available until I mark it off as SOLD
Frame with a clean title $350
Engine Support Bolts $25 SOLD
Swing arm assembly with axel bolt and frame bolt, and wheel adjustment assembly. $75
Front cyclender head assembly without cover. $100
Rear shock assembly and linkage $50
Entire front assembly - Forks with Tripple tree assembly, &axel. $300
Front and rear wheels Straight and in excellent condition. $300 SOLD
Radiator with hoses and bolts $100 SOLD
Clip ons- set good cond missing clamp bolt $50 Throttle side SOLD Brake side available for $25
Odometer assembly with 12K showing $100
Front cowl $200 great shape only light scratches, one quarter size of paint worn off, all tabs perfect, no cracks.
Front fender $50 SOLD
Front fender brackets $15 SOLD
Fairing stay assembly $50
Kick stand with switch harness. $40
Winscreen $30
Rear side tail cowlings $75 few light scratches one spot quarter size of paint worn off, all tabs perfect, no cracks. SOLD
rear grab bar $45 SOLD
kill switch $40
Throttle assemly $30 SOLD
Front brake rotors $100
Rear brake rotor $50
cush sprocket drive assembly with cushes. $25 SOLD
Front brake calipers with pads and brake lines for the pair. $100
Rear brake caliper with brake line $25
Headlights $150
Front flush mount directionals $10
Rear flush mount directionals $10 SOLD
Front wire harness headlight/directionals $50
Rear wire Harness Main harness $100
Transmission internals (Gearing, all in very good shape, motor only had 12K on it) $100
COIL ASSY,IGNIT $45
IGNITER ASSY $150 SOLD
RECTIFIER ASSY $75
RELAY ASSY,STARTER $40
STATOR ASSY $75
Cams $75
Throttle cables $35
Passenger pegs $75 for the pair
Bar end weights )Stock, right has slight rash from low side. $10 SOLD
Stock mirrors - $50 SOLD
Directional relay $10
Graves Fairing stay- SOLD
Tank I am looking for $150 shipped. SOLD
I also have two aftermarket streetfighter light assemblies that are 100% functional and good condition. The carbon fibre one is perfect.
Carbon fibre one $35
White acerbix $25 pics below for the tank and lights
If you can think of anything else you may want just ask, like I said it's the entire bike minus the motor and the items I took for my spares as mentioned above.
www.tailofthedragon.com
If your really up for a build and make a good offer for everything including what I mentioned I want I can be swayed to sell everything off.
All the bike needs to be riden is a motor, oil cooler, battery, tank, seats and exhuast. I was told everything is in fully functioning order. Clean title in hand ready to transfer!
Any idea how much could be used on a 2nd gen sv (06 sv650s)? In particular, the entire front end and nose fairing...looking for parts for an 06 that had front end collision damage.
I am now studying the exhaustive thread on fork swaps on svRider...this is gonna take awhile. 256 pages on GSxr front end swaps alone! I imagine many people on this site have been there. I really didn't intend to dive into this topic head first, but the bike kinda fell into my hands yesterday
a spare set of wheels for amandas bike would be nice...hmmmmm.....
Imbeek, do exactly what the prior owner did to my other SV, take the new motor & p ut it in this frame.
Hmm, interesting idea...I didn't even consider that. I'm not that knowledgeable on SVs...as I said, this just happened yesterday! dont know if all those other gen 2 parts which I have would fit on a gen 1 bike (your quote: all the bike needs to be riden is a motor, oil cooler, battery, tank, seats and exhuast) as well as all the parts you are taking off...especially subframe, etc.
How much for the whole ball of wax before you take stuff off?
what makes it a bit more difficult is that I take your suggestion, I would be going "backwards" in the frame age. The frame I got looks mint, not sure if gen 2 is necessarily better or not. Mine has clean title too, and if I just get a GSXR front end (or someones gen 2 SV front end after they replaced theirs with GSXR parts, should be plenty of those around!) and race plastics, I would be pretty set. (needs a few other things; rear brake pedal and shift lever, or replace all with rearsets; radiator slightly bent but not leaking.
seems like the first thing I should do is see if I can find a complete gen 2 SV front end (or maybe just forks and rotor...because of the way the accident happened, the wheel and calipers might be ok.
Opinions on which generation SV frame is better for trackday use? (so, I guess it would include cost/availability of plastics, etc)
[QUOTE=
All the bike needs to be riden is a motor, oil cooler, battery, tank, seats and exhuast. I was told everything is in fully functioning order. Clean title in hand ready to transfer![/QUOTE]
do a GSXR or R6 front end and never look back
stop looking for GSXR front ends. they will be more expensive, whereas a TL front end is just about the same and will usually be a fair amount cheaper.
Even cheaper would be these Forks all ready to go... Just bringing this back onto my subject of selling this stuff..
start your own thread Mike!
Just posted everything up for sale on SVrider, so speak up quick if you want or need anything.
Hump Day, Bump Day...
I Know there are people that want spare SV wheels.... These wheels are in mint condition.FREE Tires on there are usable as well!
did you say free wheels? ill take em!!
Is there an exhaust available? I didn't notice and I'm lazy.
swtiches... I need the right side switch pod (starter and kill), with the wires that plug into the main harness. You had all the switches listed together for $100. I don't need them all and can buy the switch pod new from the dealer for $78. Let me know if you'll let the right side pod go for cheap before I order one.
Oxx, I don't like you that much...
Gixxerjockey, you have a PM.
I need a bar end, assuming they're the same as the next gen.
I would look into that Jay, as I do not know for sure. I do have 2 bar ends. They are lightly scratched but fully functional. I'll send them to you cheap.
Can you ship me the engine support bolts for $25?
I just need one. Maybe I can just take the bike for a spin and stop by next weekend.
Both of you, plan to stop over. Mcbiggity your only 2 towns over .
Ok, need to find some time to escape from little biggles. Hold onto them and I will see when I can get some free time. What days/times usually work for you?
