I am looking for a front wheel for a 2005 gsxr1000. All model year 2006 wheels will fit. I am also looking for a stock rotor for the same bike.
thanks,
Tim
timothy.r.byma@us.army.mil
are you sure its 320mm? mine are 320 i think and they are off an 02 and i know the 05 off of Kates bike was too small. i wanna say that they are 300mm
try ebay. got mine cheap for my G/F GSXR.
i've been keeping an eye on ebay. used front rims are still bringing over $300. I figured i'd ask around before buying on ebay.
i have a 320mm rotor with the new bolt pattern. i assumed that was stock.
i would measure it. the EBC site gives a different part# for 05 06 (radial brakes means smaller rotors) go through the list and find out what else takes that rotor. the ones i got for my G/F bike were for a Busa. same rotors as the gsxr and the TL.
i borrowed a front wheel off of Kates 05 750 and the rotor was smaller than my 02 calipers so i was only using 80% of the pad. i would just measure them. check the cm and add a 0 to make mm
just checked EBC and they say 310mm
i see now that 320 is oversized for the 05 gsxr1000....
i guess i need 2 then!thanks for setting me straight.
did some change them on you? whats on there now 320?
05-06 GSXR1K
06 GSXR600 & 750 will fit your bike
i just got a cheap front end and swapped it on my '03 600... then i bought some rotors on ebay for the new radial set up but somebody screwed me over with one bent rotor.
when measuring, should i measure only the worn area where the brake pad has contacted?
well then, any rotor with the new bolt pattern will work. sweet.
just measure straight across the middle. the diameter of the WHOLE disc.
ok. still shopping for one rotor and rim. thanks.
its the right size?
yes sir.
kewl.
some of these buy it now ones look good
eBay - 06 gsxr front rotors, Parts Accessories, eBay Motors items on eBay.com
Busa will NOT fit
Whats up, I may have 2 front wheels for the 05-06 Gsxr100.I have to go through my storage.I had a shop a yr or so back doing chrome and all that custom shit.So I have mad parts but its too cold for me to be in that storage unit.But I will make a trip for you.PM me.
Thanks
sent
i have a rear gsxr rim. its the 5.5 inch (white in color)
nah, its for an SV650. i think thats a 4 or 4.5" rim. thanks though
do you know if the TLS front wheel is the same as a GSXR wheel? (i would assume so) how muchfor just the front? and how much for just the GSXR1K rotor?
