Results 1 to 16 of 16
4 goodyear snow tires on wheels
    4 goodyear snow tires on wheels ***SOLD**
    car is gone, no need for these now.
    1 season on them. i paid $475 for just the tires and mounting last year.
    these were surprisingly quiet on the highway.
    CL ad here:
    https://nh.craigslist.org/wto/5328866062.html
    Lifer NPDCPA's Avatar
    Mar 2011
    Re: 4 goodyear snow tires on wheels
    Wheels were on what vehicle?
    wheels were on my 07 caliber. IIRC the wheels were originally on a Chrysler T&C
    that lug pattern is pretty common though. id say 80% of 5 lug vehicles are this pattern
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    My pals car takes 215/60/16. Does it make any difference? I already passed the info along. He has a 2005 Mazda MPG
    Bolt pattern | Stud Pattern : Bolt Pattern list 5X114.3
    According to that it'll bolt right up to an MPV of almost any year.
    CCS/LRRS #83
    Thanks and wow I never knew about that site.
    You have to check wheel offset as well. It is usually stamped on the back of the wheel. For a FWD vehicle typical range is 30-60mm.
    It appears hub diameter is the same. Most cars are "hub centric" so that is important. Sorry if this clutters up the thread.
    This is true. The t&c has something like a 71mm hub whereas my car was more like 66mm. Lug nuts are usually tapered so i never had any issues just installing the lug nuts evenly to get the wheel centered.
    Most fwd vehicles have a high offset which is what these came off of. I looked and dont see a number stamped inside.
    The tire will be a little taller but not much. Tthe only thing yiu need to watch is wheel well clearance with the wheels fully turned. Iirc a mpv has pretty big wheel wells so it probably wont matter much. Speedo may be a couple mph off, not much though. Mine was slightly off going from the oem 215/55-18s that came on it
    I texted him and he asked a couple questions. That is where that stands.
    If you go to tirerack or the manufacturer you can look up rolling diameter and tire height.
    You can also buy qdapters for the center hub. But I believe these fit a ton of Chrysler/Jeep vehicles.
    Snow will be here before you know it. Dont get caught out on all seasons. The ability to stop and turn in the snow without the abs intervening truly is nice.
    NESR price $400
    Lifer ZX-12R's Avatar
    Candia, NH
    That tire size looks to be a hair too large in diameter for my Mazda 6 since there is very little clearance with the stock 215/50-R17s. That's too bad because the wheels have the correct lug pattern and it's a good deal overall.
    looks like they are about 1.5" taller than your current set up.
    bump
    its gonna snow eventually...
  1. For Sale - Other | Snow tires and wheels
    By 01xj in forum For Sale
    Last Post: 01-24-22, 08:33 PM
  2. snow tires & wheels
    By b0xmonkey in forum For Sale
    Last Post: 12-05-09, 11:30 AM
  3. S10 Wheels w/snow tires
    By BMFR6 in forum For Sale
    Last Post: 10-29-09, 06:40 PM
  4. Snow Tires and Wheels
    By Manny in forum For Sale
    Last Post: 10-25-09, 02:16 PM
  5. BMW E39 Snow tires and wheels
    By Shortermemory in forum For Sale
    Last Post: 10-11-07, 02:44 PM
