I upgraded to the Iphone 6 and now have an Iphone 5 sitting around. It works well, all buttons work as they should. Has a Brand New Otterbox Defender case in black and will come with 1 charging cable, i think i have the original box as well. I will not give you the Earbuds as that would be kind of Nasty Nasty!
To whomever buys it i would suggest spending the $25 on a new battery for it, the battery's usually come with the special driver to remove the back-plate and they are actually pretty easy to change, for an extra $25 ill buy the battery and do it for you before you receive the phone, It is not absolutely needed but would be suggested.
$200
I can send pictures Via Text if you PM me your phone number
Corey
Run the serial number on the Apple site, they may replace the battery for free as they did on my wife's I5.
Wirelessly posted
It's not a bad battery it's just 2 years old and doesn't hold a charge for 2 days of use anymore, normal! I did check a while back and it wasn't one of the ones with the junk batteries
Corey
