Results 1 to 12 of 12
JL Sub and Amp
    Member redwinger's Avatar
    Newburyport, MA
    JL Sub and Amp
    Selling my JL 10w3 Sub and JL 250/1 Amp. Stock Specs below. Used for a few years. Sub comes in a sealed 1cf box. Amp alone sells for $250-$300 new. I'm looking for $300 for both. Local pickup only.
    -Dave
    JL 250/1
    Class D Circuitry
    250W RMS @ 1.5 ohms - 4 ohmsTHD at Rated Power: <0.05% @ 4 ohm
    S/N Ratio: >95dB below rated power
    Frequency Response: 5 - 50,000 Hz (+0, -1dB)
    Damping Factor: >500 @ 4 ohm/50 Hz
    Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
    Differential-Balanced Input Topology: (1 pair of inputs)
    On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
    Preamp Output: 2-channel (full-range, LP or HP)
    Bass EQ: variable boost up to 15dB
    Infrasonic Filter: defeatable 24dB/octave at 30 Hz
    Signal-Sensing Turn-On: permits operation without remote lead
    Dual mono speaker output connections: accept up to 8ga. wire
    +12V and Ground connections: accept up to 4ga. Wire
    Dimensions: 10.25"L x 9.25"W x 2.36"H
    10" W3v2 Series Dual 4 ohm Subwoofer
    Power Handling:
    Peak: 600 watts
    RMS: 300 watts
    Impedance: Dual 4 ohm
    VRC Technology: Cools the voice coil
    Kapton voice coil former
    Powder-coated silver frame finish
    Elevated frame technology: Enhanced cooling
    2-1/4" 4-Layer voice coil
    Dish cone/dust-cap design
    Rubber mounting flange design
    No Warranty
    Dave
    '04 R6
    Newburyport, MA
    Re: JL Sub and Amp
    OBO Bump
    Dave
    '04 R6
    Newburyport, MA
    Re: JL Sub and Amp
    don't want to deal with ebay bump
    Dave
    '04 R6
    Newburyport, MA
    Re: JL Sub and Amp
    Bump $250 for both?
    Dave
    '04 R6
    South Shore Area
    Re: JL Sub and Amp
    got any pics of the box ? and do you ever make your way down to the boston area ??
    Newburyport, MA
    Re: JL Sub and Amp
    I don't have any pictures of the box and boston...not so much. Here is a link to the box. I purchased it from this place as well.
    http://www.ikesound.com/raptor_rap101
    Dave
    '04 R6
    Newburyport, MA
    Re: JL Sub and Amp
    amp's up on ebay right now. anyone want the sub locally so I don't have to ship it? 120 bucks?
    Dave
    '04 R6
    Newburyport, MA
    Re: JL Sub and Amp
    Amp is sold. Anyone want this sub? Cheap money? 100 bucks?
    Dave
    '04 R6
    Newburyport, MA
    Dave
    '04 R6
    Newburyport, MA
    Re: JL Sub and Amp
    really don't want this. $75?
    Dave
    '04 R6
    Newburyport, MA
    Re: JL Sub and Amp
    I also have a Rockford Fosgate P1 8" not in a box. 150w rms 300w peak. available $40 bucks.
    Dave
    '04 R6
    Newburyport, MA
    Re: JL Sub and Amp
    JL Sub and box are sold. The Fosgate 8" is still around.
    Dave
    '04 R6
