Results 1 to 10 of 10
2013 Beta 250RR - $4,700 OBO
    2013 Beta 250RR - $3,700
    - one owner
    - religiously cared for
    - amazing enduro motor with tons of torque
    - lots of refreshed essentials
    - zero issues, ready to ride
    Suspension + Chassis
    - fresh fork bushings, seals and oil
    - upper fork tubes hard anodized
    - fully serviced and refreshed shock
    - new linkage bearings and seals
    - new lower linkage arm
    - XTrig shock preload adjuster
    - new handlebars and grips
    - new throttle tube
    - new top clamp
    - fresh steering bearing grease
    - new footpegs
    - new OEM frame guards
    - new OEM seat
    Drive
    - new DID o-ring chain
    - new 13T front sprocket
    - new countershaft seal and spacer
    - Dirt Tricks Iron Man 50T rear sprocket
    - new front and rear SKF wheel bearings and seals
    - new SKF wheel spacers
    - new axles front and rear
    - new rear brake tip
    - recent rear disc
    - Fasst Co rear brake clevis
    - fresh brake fluid
    - new chain slider and guide
    - new chain shoe
    - new Michelin Enduro Comp tires
    - new tubes
    Engine
    - S3 high-compression head
    - fairly recent top end, 200psi compression test beginning of season
    - JD jet kit with power valve shim
    - X-Trainer power valve spacer
    - Samco coolant hoses + thermostat delete
    - Boano oversized water pump impeller kit
    - fresh Engine Ice
    - oversized clutch slave from the 350RR
    - Beta red anodized clutch slave cylinder guard
    - fresh clutch fluid
    - new OEM silencer + guard
    - new shift lever
    - Beta red anodized oil filler cap
    - fresh Amsoil motor oil
    - new lithium battery
    Spare Parts
    - new clutch disc pack
    - full set of extra plastics
    - new fork guards
    - OEM headlight
    - red seat cover
    - OEM head
    - OEM 49T rear sprocket
    - extra set of used OEM pegs
    - OEM top end gaskets, washers + o-ring set
    - various other OEM take off parts
    More pics.. .
    Apr 2012
    Re: 2013 Beta 250RR - $4,700 OBO
    What??? Why?
    Quote Originally Posted by Jewcati View Post
    What??? Why?
    if i was made of money i'd keep it, it's so damn dialed ... but i'm playing with a 200RR for a bit, relive those old WR days
    you still gettin' dirty?
    i can't edit the title ... price drop: $3,700
    SOLD.
    To whom?!
    Member Sideshow's Avatar
    Someone got a smokin deal.
    Now go put a deposit on a 2020 RE.
    To whom?!
    a young guy from NH, he and his buddy (on a 300RR) race JDay, etc. he test rode it last night, all i got back was... "THIS THING IS INSANE!"
    Quote Originally Posted by Sideshow View Post
    took 2 months to sell but the past two weeks i was getting flooded with inquiries. we settled on $3,840. i'm good with that. i removed all the high dollar items.
    mmm, 2020 REs are sexy ... i want those KYBs! ... Dave is testing riding them tomorrow.
    Did you do your forks? Ready to ride?
    not yet on forks. they rode nice at your place so need to test in our local trash again before swapping internals. i do want to check oil color again though.
    no dice on Wed ride working on the Cape
  1. 2020 Beta's have dropped
    Last Post: 07-15-19, 01:12 PM
  2. typeone's Beta build (250RR)
    Last Post: 06-24-19, 01:19 PM
  3. Looking to poke around on the Beta Tomorrow
    By scottieducati in forum Dirty Bastards
    Last Post: 05-02-16, 09:59 AM
  4. 2014 Beta Off-Road
    Last Post: 07-15-13, 07:00 AM
