For sale is a Razor Ground Force Drifter Electric Go Cart. Could use a wash and a squirt of oil here and there but in otherwise good condition. Needs a battery and some TLC. Comes with charger.
$100 for NESR peeps.
Batteries are available at Amazon, Target, Walmart and Toys R Us. $25.00 for two: Amazon.com: 12V 7AH Sealed Lead Acid SLA Battery for RAZOR Scooter 2PK: Automotive
Super fast, furious and fun, the Razor Ground Force Drifter has Super Slider POM rear wheels to let you power slide through corners, throw fish tails or fast 180's. Capable of speeds up to 12 mph, the Ground Force Drifter will make you the neighborhood drift king.
The steel frame on the Drifter carries up to 140 lbs. to a maximum speed of 12 mph, and the 24V battery system allows up to 40 minutes of continuous use.
Molded aluminum front wheels with solid rubber tires let you keep control while you lock the rear wheels to pull off awesome power slides, 180's or complete 360's.
The variable-speed throttle and rear brake are controlled at the steering wheel, providing easy operation.
The bucket seat comes with a lap and shoulder strap to ensure your safety while driving the Ground Force Drifter.
These sell at the box stores for $260 on sale to $299.
