Selling (2) things.
1. M25 Laser jammer. Way too much information to list on here so I'll direct you to a site that explains it all.
Essentially, its a jammer with 2 heads you put on the bike ( front and back). You also get a helmet LED kit which you put on your helmet.
When a laser is pointed at your bike and a LEO is trying to get your speed, it blocks the signal. Once the heads receive this laser hit, a signal is sent to your helmet to let you knw you'r being gunned. You then hit the brakes to the speed limit then you shut off the jammer so the LEO catches you doing the speed limit.
It works, Im only selling it because I sold my bike.
I bought it from this website a year ago , cost me almost $700.00
http://www.pashnit.com/product/cheetah_m27.html
Here is a video of how it works
YouTube- Cheetah M25 Rider - Motorcycle Laser Jammer
Selling for $300.00 , I need this sold by the end of July.
2. IM also selling the Whistler Radar Detector, it includes a helmet warning system as well.
http://www.buyradardetectors.com/pro...cruisader.aspx
Bought this for $180.00, Selling for $80.00
you are well armed.
does it jam non-laser signal?
"fuckit!"
F*ck Me!!! I wish I had the money....
PCIII, Ignition Moduel, Dynojet Quickshifter, -1/+2 Driven Sprockets, Flapper Mod, Extended Swingarm, HID, Nitrous, Custom Map, Corbin Seat, Lowering Link, Galfer Brake Lines, Greggs Flush Mounts, Comp Werkes Fender Eliminator, Speedo Healer, R6 Throttle Tube, Hyperflo Exhaust, Powder Coating.
Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
I kinda think that's the point of the helmet warning and the "turn it off" part.
It's also illegal to speed.
And it's illegal to have oral sex in Tennesee....
its illegal to block radar not laser, unless they changed the laws. Reason was that the fcc doesn't regulate light wavelengths, which is how you block laser. But to block radar you have to use an fcc controlled wave length. At least that was how it was explained to me.
Pictures of the M25?
Illegal or not the officer doesn't know you have it if you use it correctly.
They receive errors all the time ( one of them due to distance). Once you're tagged, a LED is flashed in your helmet to signal that you're being lasered.
You then hit the brakes to the speed limit then shut off the jammer ( there is a shut off switch with it) .Then the Officer gets your speed doing the speed limit.
Obviously this isn't bullet proof, you can't be going 150mph and then expect it to work like the above scenerio.
However, if you're on rt3 traveling at 65mph in a 55 mph zone and they have a speed trap setup ahead, this system will pay for itself after one save
