For Sale: 2006 Suzuki SV650 fresh Race Build. Complete frame up race bike build as follows:
• APE High Compression Cylinder/Head Stud Kit
• Stage 2 Cylinder Head Porting & Polishing
• Valve Seat Race Re-Grind w/New (Stock) Intake/Exhaust Valves & Valve Spring Collets
• New SV Pistons, Rings and Piston Pins (Stock Bore)
• Spear's Hi-Compression Head Gaskets
• Spear's Racing Steel Oil Pump Drive Gear
• Spear's Racing Star Shift Kit
• Spear's Racing Lightened Flywheel
• EBC Kevlar Race Clutch Kit (Fiber Plates, Steel Plates & HD Springs)
• Motion Pro Quick-Turn Throttle
• K&N Air Filter w/Airbox Modification
• SV Parts Fuel Tank Riser Kit
• Valve Eliminator/SMOG Back Off Plates & Spears PVC Port Plug
• ZPC Silicone "Blue" Radiator Hose Set
• M4 Full Race Mount Exhaust
• Ballistic NiCad Battery
• Dynapower Power Commander PC-5 w/Autotune
• Penske 8387 Rear Shock w/Remote Reservoir (Mounted in Tool Box)
• GSXR 600 "06" Front Forks & Radial Disc Brakes (w/Race Tech 1.0 KG & Ti Rotor Bolts)
• GSXR 600 Front Brake Master Cylinder/Clutch Assembly w/CNC Black Shorty Levers
• GSXR 600 "06" Rear Wheel w/Brake Backing Plate & Sprocket Hub Modifications
• Pirelli Diablo Supercorsa SP V2 Race Tire Set (120/180)
• Woodcraft Rear Sets w/GP Shift Set-Up & Carbon Fiber Heel Guards
• Woodcraft Clip-Ons
• DID Pro VX2 520 Chain & Vortex Sprocket Kit (15T/46T)
• Vortex V3 Gas Cap
• Stainless Steel Allen Head Engine Screw Kit
• Stock SV650 Tail Section w/Race Cowl & Undertail Tray
• Subaru "World Rally Blue" Single Stage Paint w/Eastwood 2K Epoxy Clearcoat
• Stomp Grip Tank Pads (Clear)
• Pro-Tek Frame Sliders
• Ducati Monster Front Cowl/Number Plate
• Race Italia DR404 SV650 Race Belly Pan w/Oil Containment
• Modified GSXR Speed Sensor w/Speedo DRD S1 Calibrator
• New Motion Pro Throttle & Clutch Cables
• Stainless Steel Front/Rear Brake Lines
• Street/Cafe' Option: Race Tail Cowl, Naked headlight and complete stock tail section with signals/tail light for street conversion available.
The engine has been re-built from the cases up. The chassis has been built from bare frame up with "06" GSXR 600 USD Front End Assembly, modified GSXR 600 Rear Wheel Assembly and a new Penske 8987 double clicker shock. Every nut, bolt and part has been replaced and/or reconditioned. In short, this is a new race bike and is set up, safety wired and ready for tech inspection. All street parts removed, bagged/boxed and are available but not included in sale. I can deliver to NHMS/LRRS Event or local pick up.
(Note: The final photo is the SV with the street trim). I have quite a bit of time and money invested in this project and it will make a great race bike for someone. I built this over the winter hoping to race LRRS but I am selling it due to crash injuries sustained from last fall which I am still healing from. Thanks for looking....
Asking: $4,950 or OBRO. Dirt Thumper trades considered. Call or Text Michael at 802-598-0980 Located in Ferrisburgh, VT.
