Results 1 to 6 of 6
Epiphone Dot Studio
    Epiphone Dot Studio
    As far as I know, this is an Asian market guitar (imported from Japan by me), from 2011. I’ve never seen a normal epi sunburst 2 knob like this in the states. Knobs have been switched to have the switch in front like a normal 335, and the volume pot has a treble bleed on it (so it doesn’t muddy up as you roll off the volume). Everything else is stock, best I can tell.
    Action is currently medium, as I haven’t switched it to flats and set it up like I normally would.
    It has a couple minor finish marks, a tiny bit of swirl, the most notable being the chip on the back of the headstock and the excess glue/finish buckle around the top side of the neck joint (which is pretty common across the epiphone set neck line IME). I have a single ply pick guard and bracket to install, but I’ve yet to do it, the pg still has the plastic on it, which is why it might look a little odd in the pic where I mocked it up. Fret wear is almost nil, except a tiny bit in the cowboy chord area. It’s a cool piece, I was gonna use it as a mod platform to create a sorta kooky one off, but I found another that I like in almost stock trim that really suites my fancy as is.
    $300
    Epiphone Dot Studio-1467111d-1e44-4937-a5d4-c2bb4fd62c23
    Epiphone Dot Studio-01c94358-baa4-455b-9dc4-802e37d48a58
    Epiphone Dot Studio-a74dbafc-c858-4d2a-97b8-c27e2947fcd9
    Epiphone Dot Studio-f528e7f6-3382-42ac-9d2d-78f467670eed
    7.75lbs
    Lifer gixxer72's Avatar
    The desert
    Re: Epiphone Dot Studio
    $300
    7.75lbs
    Nice looking. I don’t own any semi’s, but that seems heavy? (Not a bad thing, I don’t mind weighty guitars at all)
    It’s got a maple center block.
    You know guitar nerds, they gotta know.
    Jun 2005
    Nice lookin' fiddle.
    Casual bump.
    $250 for homies here. Plus shipping, if applicable.
    Lifer capitalcrew's Avatar
    Feb 2017
    Albany NY
    When I was 16-18 I wanted one of these so bad. Was too busy wasting money on everything else imaginable though. Bump for a good deal.
  1. For Sale - Other | Studio speaker stands
    By Jewcati in forum For Sale
    Last Post: 06-22-17, 09:17 PM
  2. Gibson Epiphone Les Paul Limited Edition + Accessories
    By Quaint Taint in forum For Sale
    Last Post: 01-18-14, 05:41 PM
