Results 1 to 3 of 3
Traxxas Slash 4x4 Platinum
    60% squid duganc1717's Avatar
    Dec 2008
    Framingham
    Traxxas Slash 4x4 Platinum, bought new this winter and have run about 8 battery packs thru it, VXL brushless, low center gravity chassis, aluminum parts, etc. Also comes with a set of Proline Trenchers that are almost new and a set of Proline TSL Super Swampers 2.8", three bodies, including blue Ford Raptor, Proline adjustable body mounts (all bodies have some rash), Futaba 3PL 2.4GHz FHSS radio/receiver, SPC racing 3S battery. $425 or trade for Axial Wraith Spawn
    Does not come with charger!
    Product Description
    This is the brushless electric powered, radio controlled, almost ready to run
    1/10 scale Traxxas Slash 4x4 Platinum Edition Short-Course Racing Truck.
    The differences between this version and the 6804 are a new Low CG Chassis
    and GTR High Volume Shocks on the 6804R.
    Requires transmitter, receiver, batteries, charger
    and paint for the body.
    FEATURES:
    Chassis: Nylon composite construction 0.08" (2mm) thick bathtub type
    Drive: Four wheels of chassis
    Electronic Speed Control: Traxxas VXL-3S waterproof, with high-
    current connector, training mode, reverse and low voltage
    detection for use with 2S and 3S LiPo packs
    Motor: Traxxas Velineon 3500 with ultra high temperature
    Neodymium magnets and high speed ball bearings
    Spur Gear: 45 tooth
    Pinion Gear: 31 tooth 48 pitch, extra pinion gear included for 50+
    MPH operation with extra battery
    Body: Clear polycarbonate with overspray film and window masks
    Bumpers: Front and rear, composite construction
    Shocks: Hard anodized oil-filled aluminum body GTR with PFTE coated
    13mm bores and titanium nitride shafts for smooth, consistent
    damping
    Suspension: C-hub design, front and rear sway bars
    Transmission: Ball bearing equipped
    Differentials: Sealed silicone filled planetary gear type, center
    diff installs trackside in minutes replacing the Torque Control
    slipper
    Ball Bearings: Rubber sealed
    Caster: Non-adjustable
    Camber: Adjustable, camber refers to the angle of the tops of the
    tires from vertical when viewed from front or behind vehicle
    Tires: Licensed BF Goodrich soft compound Mud Terrain T/A 4.3"
    (109mm) diameter, 1.7" (43mm) wide
    Wheels: 5-spoke brushed chrome, 0.98" (25mm) wide, 1.4" (35mm)
    diameter, standard size 12mm hex.
    Dec 2008
    Framingham
    Re: Traxxas Slash 4x4 Platinum
    TTT
  1. For Sale - Other | Ariens Platinum 24 SHO Snowblower
    By zxme in forum For Sale
    Last Post: 10-27-22, 05:38 PM
  2. For Sale - Other | 2018 Trek Slash 8 18.5" ML with Upgrades
    Last Post: 08-19-20, 09:48 AM
  3. For Sale - Other | Traxxas Nitro 4Tec 2.5 - Basket case with extras - $50 or trade for something neato
    Last Post: 01-25-16, 12:16 PM
  4. For Sale - Other | FT: 2016 Trek Slash 7 650B Sz 18.5" , Looking for a Dirty Bike
    Last Post: 11-16-15, 07:31 PM
  5. VMax slash-cut Cobras
    By old timer in forum For Sale
    Last Post: 04-07-11, 05:39 PM
