1
Traxxas Slash 4x4 Platinum, bought new this winter and have run about 8 battery packs thru it, VXL brushless, low center gravity chassis, aluminum parts, etc. Also comes with a set of Proline Trenchers that are almost new and a set of Proline TSL Super Swampers 2.8", three bodies, including blue Ford Raptor, Proline adjustable body mounts (all bodies have some rash), Futaba 3PL 2.4GHz FHSS radio/receiver, SPC racing 3S battery. $425 or trade for Axial Wraith Spawn
Does not come with charger!
Product Description
This is the brushless electric powered, radio controlled, almost ready to run
1/10 scale Traxxas Slash 4x4 Platinum Edition Short-Course Racing Truck.
The differences between this version and the 6804 are a new Low CG Chassis
and GTR High Volume Shocks on the 6804R.
Requires transmitter, receiver, batteries, charger
and paint for the body.
FEATURES:
Chassis: Nylon composite construction 0.08" (2mm) thick bathtub type
Drive: Four wheels of chassis
Electronic Speed Control: Traxxas VXL-3S waterproof, with high-
current connector, training mode, reverse and low voltage
detection for use with 2S and 3S LiPo packs
Motor: Traxxas Velineon 3500 with ultra high temperature
Neodymium magnets and high speed ball bearings
Spur Gear: 45 tooth
Pinion Gear: 31 tooth 48 pitch, extra pinion gear included for 50+
MPH operation with extra battery
Body: Clear polycarbonate with overspray film and window masks
Bumpers: Front and rear, composite construction
Shocks: Hard anodized oil-filled aluminum body GTR with PFTE coated
13mm bores and titanium nitride shafts for smooth, consistent
damping
Suspension: C-hub design, front and rear sway bars
Transmission: Ball bearing equipped
Differentials: Sealed silicone filled planetary gear type, center
diff installs trackside in minutes replacing the Torque Control
slipper
Ball Bearings: Rubber sealed
Caster: Non-adjustable
Camber: Adjustable, camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
Tires: Licensed BF Goodrich soft compound Mud Terrain T/A 4.3"
(109mm) diameter, 1.7" (43mm) wide
Wheels: 5-spoke brushed chrome, 0.98" (25mm) wide, 1.4" (35mm)
diameter, standard size 12mm hex.
TTT
