1973 Yamaha RD250, converted to 358cc. Just built. $3,500. Pick-up in Central CT, 10 minutes from Hartford.
o Wiseco pistons and rings, .040" oversize
o Wristpin bearings
o RD350 cylinders and heads
o Crankshaft seals (Japan)
o Crankshaft bearings- outer
o Ultrasonically cleaned carburetors (main & pilot jets, synchronized)
o Fuel Petcock Rebuilt
o Stainless Allen head engine bolts
o Yamaha factory air filter
o Steering bearings lubed
o Front fork seals and boots
o Grips
o Battery
o Seat cover
o Bridgestone BT45 tires (200 miles on them)
o Chain and sprockets
o Spark plugs
o Premix
o Points and condensers, timing set w/ dial indicator
o Fuel lines & fuel filters
o Turn signals, horn, brake lights all work
