https://www.autoshades.com/products....-Europa-Mark-I
Have a "premium" rear window sunshade. It is similar to those found in Audi's, BMW's, Mercedes, etc. except it is not electrically controlled.
Have one installed on my car and love it. Bought this for a friend but they ended up getting a new car that this does not fit.
This will fit any car with a rear windshield width of 38"-41". Most mid-sized sedans fall under this category. Installation is super-easy, just attaches using adhesive velcro and tension. No screws or drilling required.
Description from website
TRuly outstanding! This sun shade will take you to the head of the class.......First Class, that is! Patterned after the see-through sun shades available in some of the more luxurious European cars, the 'Europa MARK I' rear window shade will make you feel like you're in Seat 2A instead of your driver's seat. This roller-type sun shade with automatic withdrawal, uses its patented tension mechanism to fit just about anywhere on your rear window shelf including around those top notch speakers you bought for a small fortune - or on your hatchback door. Its fine, black mesh material provides good such good visibility and sun deflection that many vehicle owners use it in its engaged position, year round. When you finally decide to disengage the shade, the automatic withdrawal function rolls the shade down into it base housing quickly and efficiently. Talk about a class act! Available in three sizes based on the width of the glass area at the TOP of the rear window. Height extension: 23"
This is brand new, never installed, still in the original packaging.
Sells for $70 shipped only at the above link...Ill let it go for $50 shipped.
'02 F4i
Bump
'02 F4i
BUMP $50 SHIPPED
'02 F4i
