Results 1 to 11 of 11
Braking bumps
    Lifer Pittenger5's Avatar
    Austin
    Braking bumps
    Weight forward or back?
    Zip Tie Alley #505
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Re: Braking bumps
    Weight centered. Balls of your feet should be on the pegs with your knees gripping the tank. You will want to be in the attack position. It is key to hold on with your legs and stay as loose as possible on the bars while braking through large braking bumps. One trick to braking bumps. Often times you can charge a little deeper into the turn and do most of your braking beyond the worst of the bumps. Often times the bumps form up early on entry into the turn. If you can stay neutral or on the gas through them the front suspension can deal with them much better than on the brakes.
    Re: Braking bumps
    Yeah, great post Rada. And the bumps are often so sharp that the slow you quite a bit even on neutral throttle.
    Austin
    Re: Braking bumps
    Yeah, I notice they form usually a bit sooner than Id brake, so Im not usually hard on the brakes through them.
    Zip Tie Alley #505
    Re: Braking bumps
    Damn four strokes downshifting and making a mess of the entrances to turns...
    Re: Braking bumps
    do what I do...
    come into a turn too hot, hit the braking bumps and just wipe out
    Re: Braking bumps
    do what I do...
    Refresh the suspension, then realize that an XR100 at a MX track is like my GS at Loudon... it's not possible to enter T1 'too hot' on it without JATO assist.
    Re: Braking bumps
    go on...
    is it cost efficient?
    I can probably get a YZ125 for like f'teen hunn-ed that's valved and sprung for MX
    actually no...forget that...back to braking bumps
    Re: Braking bumps
    No, it's not worth it, it's an xr100. Neutral weight, transitioning fwd for the corner.
    Re: Braking bumps
    ya, the XR stays like my FZR - bone stock!
    well...except the 16" CRF front wheel, so I can get a pair of BT45'w for mini supermoto
    Re: Braking bumps
    I didn't say replace, I said refresh. New fluids, replace sloppy bushings, repack or replace bearings as appropriate.
  1. braking
    By Marc R in forum General Bike Related
    Last Post: 08-01-12, 02:26 PM
  2. Braking - doing it wrong
    By Wanderer in forum General Bike Related
    Last Post: 05-01-11, 10:40 AM
  3. trail braking
    Last Post: 08-08-07, 10:27 AM
  4. Braking/cornering Q.
    Last Post: 02-15-06, 07:41 PM
  5. Can you say late braking????????
    By Rye in forum Pit Area
    Last Post: 06-24-03, 09:37 AM
