Results 1 to 18 of 18
Chain Guide Question
    Todd Twheat18's Avatar
    Stow, MA
    So I swapped my chain and sprockets on my kx125 this afternoon. The new chain is a 520 x ring. The old chain was a non ring conventional 520. My new chain binds up in the chain guide. What should i do about this? Cut the plastic walls down or let the new chain do its thing? I'm a total newb to this stuff so input is much appreciated.
    Re: Chain Guide Question
    The chain guide before the rear sprocket (bottom) or the the one on top of the swingarm pivot area? If it was minor rubbing, i'd say let it do it's thing. You just need to keep an eye on the master clip if you have one, the constant rubbing until the plasic wears out could pop the clip off
    Stow, MA
    Ya its the bottom chain guide. And that was one of my major concerns, the effect on the master link clip. Also any premature wear on the chain pins.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    At least make sure that the master link clip is on in the correct direction. That the wide end goes thru the plastic block first.
    Are u sure the front sprocket is facing the right way????? Poss backwards..
    Stow, MA
    Ya I did that. Just concerned about how much is actually to rub on the guide
    Stow, MA
    I'm certain its on correctly. However I fail to see how sprocket orientation has anything to do with chain width. Care to enlighten me?
    Lifer DuncanMoto's Avatar
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102 UP.Link/6.3.1.20.0)
    His comment was related to chain alignment.
    He was most likely picturing the chain rubbing only one side.
    Stow, MA
    Quote Originally Posted by DuncanMoto View Post
    OK. That makes sense I suppose. However not the case. Its rubbing on both sides.
    BTW Ted the vholdr is working great.
    Lifer eboos's Avatar
    I can't tell you what you should do. I can only tell you what I've done. I just let the chain do it's thing.
    Stow, MA
    Quote Originally Posted by eboos View Post
    I think that's the conclusion I've come to. Ill just make sure the clip is facing the correct direction so it doesn't get pulled off.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    or do what I do, no X or O ring chains and buy a new one every year...
    Posted by Jane in BoxChat
    KB KB's Avatar
    Manchester NH
    Ride it the guide will be the right size in about 500 feet.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Stow, MA
    I know I guess I could have done that. I was under the impression that a conventional chain was not gonna last at all on dirt. Probably should have just paid 1/3 the price and replaced more often.
    KB KB's Avatar
    Manchester NH
    I spend the $ on a Regina chain and have it last a while. Personal preference I guess. Just run it and the chain will do it's thing.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    I did the same thing earlier this season. After 10 minutes the guide is in the new shape of the chain. No issues.
    2016 BMW S1000XR
    Yowza LaRNZ's Avatar
    Oct 2004
    Tewksbury , MA
    try riding the first bike you vagina, then worry about the chain guide
    .:|LaRNZ|:.
    The #'s on the front sprocket face out.
  1. Chain question
    By bluej511 in forum Bike Maintenance
    Last Post: 08-26-09, 11:34 PM
  2. Another Chain Help Question
    By idratherberidin in forum Bike Maintenance
    Last Post: 06-12-08, 12:50 PM
  3. Chain question
    Last Post: 01-05-06, 03:57 PM
  4. CHAIN QUESTION??
    By JJ in forum General Bike Related
    Last Post: 07-24-03, 04:51 PM
  5. chain question
    By oreo_n2 in forum Bike Maintenance
    Last Post: 04-10-03, 06:02 PM
