Results 1 to 17 of 17
Clutch issues
    Lifer McBiggity's Avatar
    May 2003
    Charlton, MA
    Clutch issues
    I'm having an issue where the clutch will not disengage and I can not adjust the cable enough.
    The cable is brand new, and even with all the threads showing at the adjuster as well as the perch, it still will not fully disengage the clutch.
    Any ideas??
    it's a 94 WR250.
    Lifer LuvDog's Avatar
    Ashland, MA
    Re: Clutch issues
    Did you put in a new clutch pack too?
    2003 ZX7R
    1995 916
    KB KB's Avatar
    Manchester NH
    Re: Clutch issues
    Worked fine when I owned it.
    Wait a minute.....................you should not have any threads showing at the perch. The threads should all be inside the perch and then when the cable stretches you adjust the adjuster out to make up for the play. You want as few threads showing on each adjuster. The one at the perch and the one at the moutn on the case and the one in the middle of the cable.. When all the threads show you have the adjustment all the way out not in. Call me. You fucked something up. That clutch is new. I put it in.
    I will send you monies on friday.
    Call me. You wanna ride dirt saturday???
    LRRS/CCS EX #13
    GMD COMPUTRACK
    May 2003
    Charlton, MA
    Re: Clutch issues
    Got a cookout at my house Saturday, will be riding locally in the morning. I'll check it all over again.
    May 2003
    Charlton, MA
    Re: Clutch issues
    And the clutch cable went on way too easily. It's the correct cable, but there is just way too much slack in it.
    Re: Clutch issues
    Quote Originally Posted by McBiggity View Post
    I had that problem once with a quad I had, I ordered a new clutch cable and the part numbers matched but the length was different and it didn't work. Ordered a new one with the exact same part number and it worked Just a thought
    May 2003
    Charlton, MA
    Re: Clutch issues
    yeah, i just can not get this cable to work. tried routing it a million different ways. Including the OEM routing, still no way to get it to function.
    Lifer DuncanMoto's Avatar
    Re: Clutch issues
    does it have another adjustment halfway down the cable like the KLX bikes do?
    May 2003
    Charlton, MA
    Re: Clutch issues
    nope, just the adjustment at the perch and then another adjustment about 6 inches from there
    Re: Clutch issues
    I too ordered an a/m cable once - wrong length came in
    2003 YZ250 Blue #416
    1999 YZF R6 # 602 *
    Dec 2005
    Near The Dragon
    Re: Clutch issues
    Quote Originally Posted by DuncanMoto View Post
    Get out while you can
    Find your own path
    May 2003
    Charlton, MA
    Re: Clutch issues
    Quote Originally Posted by Cerberus View Post
    it's not half-way down the cable. haha
    Dec 2005
    Near The Dragon
    Re: Clutch issues
    fair enough. i know nothing about the bike in question or its clutch.. i just thought the quoted bits were funny in relation to each other
    Find your own path
    Re: Clutch issues
    is it hooked up at the other end or is it just hanging there?
    Re: Clutch issues
    tie a knot in the middle.
    May 2003
    Charlton, MA
    Re: Clutch issues
    haha, well we came up with a solution just short of tieing a knot.
    Will find out tomorrow when we go riding
    Worcester, MA
    Re: Clutch issues
    if it works, i would like to be known as the "2 stroke engine whisperer"
    if it doesn't work, i had nothing to do with it.
    LRRS EX #165 (formerly)
  1. Hydraulic clutch issues
    Last Post: 10-03-16, 05:57 PM
  2. Issues reinstalling 2006 R6 Clutch Cover!
    By WinVT in forum Bike Maintenance
    Last Post: 07-12-12, 12:36 PM
  3. clutch issues
    By SVRACER01 in forum Bike Maintenance
    Last Post: 05-01-12, 05:31 PM
  4. HELP ! CLUTCH LEVER/CABLE ISSUES!
    By 01YZF6 in forum Bike Maintenance
    Last Post: 10-09-05, 10:25 PM
  5. New clutch cable issues
    By neuthunder in forum Bike Maintenance
    Last Post: 07-31-05, 05:27 PM
