Results 1 to 7 of 7
filter oils
    FYYFF theothersean's Avatar
    middle of nowhere
    filter oils
    I ripped this off from thumpertalk.
    I have been using the notoil flter stuff because its so easy to clean up but this litte vid might change my mind on that.
    http://www.youtube.com/watch?v=fpzK6Wm_BDs
    12 Vstrom 1000
    09 KLR 650
    (hers)
    13 Vstrom 650ADV
    09 KLR650
    filter oils
    The no-toil in my garage is going in the trash.
    thanks for the link Sean.
    degs
    filter oils
    I've been meaning to ask... I have a leftover bottle of the red K&N filter oil. Is it kosher to use on foam filters? I already used it once on a new twinair. I just can't imagine it's any different from other stuff.
    middle of nowhere
    filter oils
    I would imagine its the same stuff.
    The Notoil stuff is great as far as clean up goes, no need for solvents, but I guess it stands to reason, if the oil is biodegradeable and water soluable than obviously it lets water through in the air box.
    Lot of useful info over there on thumpertalk too bad there is like 1000+ pages of stuff in each catagory to filter through.
    12 Vstrom 1000
    09 KLR 650
    (hers)
    13 Vstrom 650ADV
    09 KLR650
    filter oils
    I think it would have been more acurate if he had used the same type of filter and the results would have been different. If you increase airflow through a filter, you must increase the size of the little passages. Aftermarket filters generally allow far more airflow than stock, which will also let more water in if that's the case?
    He used a stock filter and it pretty much didn't leak, both the aftermarket filters leaked. Not saying the idea isn't the same, but it should have been done with the same filter
    Just Registered SQUIZZ636's Avatar
    May 2005
    nashua
    filter oils
    the only thing with the K@N filter oil is made for a paper filter not a foam filter. But as long as you clean it every time, it really dosn't matter what oil you use.
    lis
    no regrets!!! life is just too short
    01 YZ426 motard (sold)
    99 YZ250 (sold)
    klx 110
    filter oils
    I've had good results using 2-stroke oil for filter oil. One of the parts guys at the dealer said try it way back when I was in high school and I've been using it ever sence. Golden Spectro to be exact. It also washes out with Dawn dish soap, simple green or castrol super clean all mixxed with water
  1. K&N X-Treme Motocross air filter vs. Foam filter?
    By Ductard in forum General Bike Related
    Last Post: 07-14-15, 01:05 PM
  2. Mixing Oils
    By pontifex in forum Bike Maintenance
    Last Post: 11-04-13, 09:44 AM
  3. oil filter
    Last Post: 12-12-08, 02:35 PM
  4. What's in YOUR oil filter??
    By legalspeed in forum General Bike Related
    Last Post: 08-09-02, 02:13 PM
