Page 7 of 9 FirstFirst 123456789 LastLast
Results 151 to 175 of 206
Dirty bike options
  1. #151
    Re: Dirty bike options
    Hrmm... only a 125, but I've got wheels that should work on it already (Ice tires?) and there are KTM places locally so it's likely going to be easier to keep in repair than the Cagiva. I'll email the guy and see what kind of shape he claims the bearings/etc are in, unless you're game for checking it out for me?
    BTW, am I still going to be checking out that TTR for you or is the YZ85 chassis project superceeding the TTR? : ) (KX85 and KX100 for sale on my road if either of those will work instead, I can get pics/etc tomorrow for you.)
    Senior Member FTMS's Avatar
    Warren, NH
    I can check it out if you want but he might be just as close to you.
    I got the TTR125, hence looking for a YZ85 chassis and 17" wheels, and maybe some set up geometry numbers so that I can go after Aaron.
    2004 Honda VTR
    1998 Honda VTR (Track Bike )
    1990 Honda CB-1
    1973 Yamaha RD350
    http://www.ftmsnh.com
  3. #153
    Schaweet! I'll keep my eyes peeled for ya.
    On the KTM, tell me these numbers are wrong:
    http://www.bikez.com/motorcycles/ktm...25_vc_1991.php
    11hp, 250lbs?!
    Warren, NH
    Those appear to be for a VC not an EXC. EXC is 202lbs but I don't know what the hp #'s are. One of my custumers has a 1999 125 EXC and it is not a bad bike. It is pretty tired and needs a rebuild but it is a fun bike in the woods.
    2004 Honda VTR
    1990 Honda CB-1
    1973 Yamaha RD350
  5. #155
    Member Fast_Eddie's Avatar
    Jul 2005
    Framingham
    Kurlon, I don't know much about the 1991 ktm's, but the 2003 model that tall Joey rides is closer to 30hp. PK also rides a 2003~2004 125 SX and he never seems to be lacking power.
    http://www.dirtrider.net/forums3/sho...?threadid=5270
  6. #156
    Do it! take shock off to inspect swingarm for play. Check steering head, then buy it and ride MF!
    And... it sold before I could get to it. Damn work.
    Warren, NH
    It's older but may be worth a look.
    YZ125
    2004 Honda VTR
    1990 Honda CB-1
    1973 Yamaha RD350
  9. #159
    Warren, NH
    2004 Honda VTR
    1990 Honda CB-1
    1973 Yamaha RD350
  10. #160
    Warren, NH
    2004 Honda VTR
    1990 Honda CB-1
    1973 Yamaha RD350
  11. #161
    That WR250 caught my eye last night actually. Specs seem decent (220lbs, 45hp or so?) and a few reports that it is luggable due to gearing/motor tune? I'm assuming that I'm not able to ride it hard enough that a day in the dirt at MX207 is going to kill it?
    Warren, NH
    The motor has a heavy fly wheel which gives it lugging ability. I am sure the transmission gearing helps also. It can take a day or two at the MX track. There is a guy at my local track that is there just about everyday with a WR250F. He just turns his compression adjustments up for the day. When you get to the point that you are launching 40+' doubles you will need to start worrying about suspension.
    2004 Honda VTR
    1990 Honda CB-1
    1973 Yamaha RD350
  13. #163
    Central MA
    The only thing I have heard about the 2-stroke WR's is that some of them have the ceramic coated cylinders, and are very expensive to replace if they get damaged. You might want to do a little research on that before jumping on it.
    I have had some cylinders re-chromed or sleeved, but I have never messd with a ceramic one, nor have I heard of any re-coating options.
    This ad indicates that the motor was just "rebuilt', but you might want to ask more detailed questions about that.
    Edit: BB shows the cylinder at about $500, the piston at $110, and the rings at $90
  14. #164
    94 cr125 is hard to beat. Get it for 600 bucks. parts are plentiful and relatively cheap. bike is easy to ride and very woods-able. That one likely needs bearings and such.
    live to ride seth399's Avatar
    Feb 2007
    CA
    just get that sled and bring it to 207
    LRRS #399
    MX #505
  16. #166
    Warren, NH
    2004 Honda VTR
    1990 Honda CB-1
    1973 Yamaha RD350
  17. #167
    Warren, NH
    RM250
    This is 15 min from me.
    2004 Honda VTR
    1990 Honda CB-1
    1973 Yamaha RD350
  18. #168
    Jul 2005
    Framingham
    Josh, go grab that RM ASAP.
    Feb 2007
    CA
    Quote Originally Posted by Fast_Eddie View Post
    ya seems like a good bike for him (in price range!) if it is running ok and all that
    LRRS #399
    MX #505
  20. #170
    It's down to that RM vs the 1994 WR250 in my neck of the woods. $600 for the RM, needs swingarm bushing kit but has extras, weighs a ton (250lbs DRY). The WR is a bit milder due to heavier flywheel, woods suspension setup, and lighter (220lbs DRY) but $100 more and the tires are old.
    The weight numbers I found for the RM are for the 1991 RMX, did they make an RM in 91?
    Feb 2007
    CA
    yes they dids!
    LRRS #399
    MX #505
  22. #172
    Warren, NH
    Yes they made an RM in 91, dry weight is 249lbs, that is the same as my YZ.
    Swing arm bearing kit about $65
    2004 Honda VTR
    1990 Honda CB-1
    1973 Yamaha RD350
  23. #173
    So, before I pull a trigger, am I correct in noting plastics are not readily available for the RM? The WR takes 1993 YZ250 plastics AFAIK and it looks like UFO makes them for it.
    ...I hate making decisions like this dangit. : )
    Warren, NH
    Aftermarket plastic is available. I see UFO stuff for it.
    2004 Honda VTR
    1990 Honda CB-1
    1973 Yamaha RD350
  25. #175
    Quote Originally Posted by FTMS View Post
    Acerbis has some avail too
  1. Wanted - Motorcycles | 80's or 90's dirty bike
    By boosten lebaron in forum Wanted
    Last Post: 07-05-22, 10:27 AM
  2. Track day bike options?
    By 7470racer in forum Pit Area
    Last Post: 09-14-14, 10:25 AM
  3. I need a new dirty bike
    By BMFR6 in forum Dirty Bastards
    Last Post: 04-12-10, 07:43 AM
  4. Dirty Bike
    By Cowboyrider in forum For Sale
    Last Post: 05-22-08, 04:52 PM
  5. Buying a bike from out-of-state: transport options?
    By number9 in forum General Bike Related
    Last Post: 11-18-05, 02:18 PM
