I was just reading the "Woods Tire" thread, and instead of going offtopic, I figured Id start a new thread.
I run like 25-30 psi in my 80/20 street/dirt tires
In that thread people were saying they run like 9psi in dirtbike tires?
Now, if im true dualsporting, dirt roads, tar roads, trails, id leave my tires alone
But I occasionally do some nasty trails with 2 friends that ride Yamaha 450 and 250 MX bikes with knobbies (I work my ass off and they have to wait for me), and the trails are very rocky, occasional deep mudholes, dirt trails, etc
If im going on a strictly dirty ride, should I drop pressure? or are on/off tires not really going to like that?
Thanks!
On your ATK? Airing down makes a big difference, airing back up can be a pain if you ride pavement to get to the dirt. A friend of mine bought a Slime brand battery powered air pump, removed the plastic case (cuts it's size in half) and it packs pretty small and runs off the bikes battery. I may do the same.
Yes, drop some pressure in the woods. They'll just wear a little faster during the pavement section you ride till you fill em back up. 12psi is "pretty much" the standard dirtbike pressure. With 80/20 tires I'd start at 18, and drop them a little at a time to see what felt best. I don't think I'd go down to 12, but you never know. It depends on the tire itself, the terrain, and the suspension.
The worst damage you could do is pinch flat, or ding up the rim on a rock with a bad hit.
Brap.
The tires are avons
The terrain is quite nasty, the rock climb section reminds me of a very weak "erzberg rodeo"
Bike has white power suspension, front forks were GMD rebuilt/stock spec, back shock is stock, and im sure not sprung for someone my size.
thanks for the advice though guys! Next trip Ill air down and bring the go-pro!
Your ATK, shod with those Avon's, is pretty much a street bike, IMO. I probably would not bother airing down to 12-14 PSI like a real dirt bike. No matter what you do with tires like those, you are not going to have much grip under true of-road conditions. The weight of your ATK is the other big factor. High weight, combined with street tires = Relatively little forward motion, and sketchy handling.
"or are on/off tires not really going to like that?" - Yes.
JMO. I have owned 650cc Dual Sport bikes. Putting real dirt tires on them is the only way to actually enjoy riding them off-road.
I don't know man, I ride dirty with it all the time, and it isn't that heavy of a bike really.... Its air cooled, and there isn't much to it, and what there is is aluminum
Ive literally gone mudding with it lol
Edit: it only weighs 280 lbs with 50 hp
Like Greg said, those are far from dual sport tires. On a good day they're 90/10's at best. That is what is holding you back off road.
Jeff
The ATK 605 deserves good tires! At least throw a Kenda Trackmaster II on the rear, and a Pirelli MT-16 on the front (This should run you about $120). You will still be street legal (both are DOT approved), but you will be able to maintain a good pace off road, without risking your life! Bonus: You will actually have FUN! Instead of just trying to remain upright. Run 12-14 PSI all around.
I did not mean to sound so condescending. Lowering pressures in those tires will probably not work very well, but you can try it. Your bike is *neat*!
