Results 1 to 25 of 26
franklin vs wrentham
    Jan 2010
    cny
    man just tried wrentham this past weekend. what a blast. so much bigger and more technical than franklin. really enjoyed it.
    thoughts?
    Re: franklin vs wrentham
    never been to either. i aspire to get there someday...now that my trailer is on the road, a bunch of doors just opened. those that have ripped those places, compare to freetown as well. (man loop and parking lot side)
    I like wrenthem Its big Very technical Not really fast. I go to franklin Cause its easy to get to from Cambridge. If you want REAL technical go to Foxboro on the otherside of route 1 That place is perfect (for a trials bike)
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Lifer union's Avatar
    Blackstone, MA
    Quote Originally Posted by gamorg02 View Post
    thoughts?
    How much of Franklin have you gone through? Im planning on riding there this weekend at some point. Either Saturday afternoon or Sunday after F1. Come on out its usually a pretty good time.
    James
    Jan 2010
    cny
    Quote Originally Posted by BLACK SQUIRREL View Post
    hmm dually noted! once i get the XR carb issues figured out I will. right now its tough as off idle the carb sticks a bit, i guess due to the vacuum from the intake pulling the slide. got a spare carb to start swapping parts though. Also need to jet it properly for the snorkle missing (have jets)
    saturday i'll be in CT playing rugby so thats out, and dependent on that I may try out franklin sunday. keep me updated which day you're going. i'd love to get the carb (re: above) figured out first though if i have the day off too.
    what time were you thinking James?
    Blackstone, MA
    Like 2 or 3 on Saturday I have things to do in the morning. Not sure about Sunday. PK said he might want to go in the morning so Ill try and figure out a time.
    James
    ok, just post up and I'll likely join ya
    Blackstone, MA
    Wirelessly posted (TELECA-/2.0 (BREW 3.1.5; U; EN-US; SAMSUNG; SPH-M810; Teleca/Q05A/INT) MMP/2.0 Profile/MIDP-2.1 Configuration/CLDC-1.1)
    Quote Originally Posted by breakdirt916
    I can meet you at the water tower at 3 if you want to ride. Still not sure on a time for sunday
    James
    Saturday/3/water tower sounds good
    I'll be on the bike that works (the XR)
    what a fuckin blast. I'm still slow as all hell, and I was exhausted after only 1 short loop of the main forest, but man do I love getting in 3rd (and sometimes 4th) gear, standing up, weaving side to side to find the best line, and just bouncing over the rocky/rooted terrain at Franklin.
    James left me in the dust but lead the way today on the CRF250. Thanks for waiting at intersections man
    we did the main forest and the beaver pond loop, then I took a quick solo run to snap some trail photos...and ended up just riding for another hour before going home. Surprisingly, towards the end of the day, I enjoyed just cruising down the roads in 2nd gear, seated the whole time, and just enjoying the scenery.
    I only ate it once
    Jan 2010
    cny
    I only ate it once
    looks like a blast guys! i know that rock in the last one. how do u get to the beaver pond loop?
    man wish i coulda been there but too beat up from rugby. spent all day trying to jet my xr250. i'm getting pretty frustrated with it, anyone want to help?
    Oct 2005
    Wrentham MA
    Wrentham State forest sucks... Everyone keep away -
    and don't take the tunnel connector that goes under 495 to other trails....
    Lots of ledge with big steps everywhere...
    I live in Wrentham :-)......
    Seriously, if you go there don't use open pipes, don't let anyone going with you use loud pipes (houses on every side) - this will get the place off limits real quick -
    Also if your bike is not off road registered it will be impounded.
    have fun
    Graham
    not sure I can help...I don't know a whole lot about fine tuning, and my XR stalls if I go WOT, off-idle. And while I know the 2-smoke carb in and out, I'm not sure I can do much more than clean and change the needle position and swap jets on a 4-stroke carb
    what do you mean by, "the slide sticks a bit"?
    I also don't know how to get to the beaver pond loop...I could probably guess though...you want me to show ya sometime this week?
    Quote Originally Posted by xsiliconkid View Post
    in Franklin or is that in Wrentham?
    also, how could you live so close and not be out there?? come join us!
    Jan 2010
    cny
    yea i can do all that but having a hard time determining which way to go with the needle/jets etc. the slow jet was easy. i kept turning the fuel screw out and it kept liking it more, obviously needed a bigger jet. the mid/WOT is bugger. only at mid/high rpms too. wot off idle works.
    there is a known issue where the slide gets used so much i guess it sort of wears in and sticks to the intake side and it takes more pull that usual to get the slide to go back on track. fixed that issue though...
    yea looks pretty easy. just take beaver st or whatever there to the pond eh? or take the tracks down and around
    oops...maybe I don't anything about carbs!
    I thought: adding pods = less restriction for intake = more air = add bigger size jet to compensate for increased air and supply more gas to get correct air/fuel ratio
    I always thought turning the fuel screw out leaned out the air/fuel mixture...but I think it's reversed on some carbs. But yes, you should need a bigger pilot jet for the low end because you're getting more air regardless.
    so for mid throttle: what's the response like? changing the needle position can help here
    and at WOT throttle: what's the response like? changing the main jet will help here. If it's anything like a 2-stroke, then doing a WOT throttle run in a high gear with a fresh plug will give you an indication how the main jet should be jetted: if black, it's too rich and so forth.
    did you adjust the float height properly, is the engine (top/bottom end) in good shape, how's your air filter, is the oil relatively fresh, and what color is the plug when you pull it?
    Jan 2010
    cny
    i'm 99% sure these carbs, unscrewing the pilot screw is more fuel. so i agree with you that since the snorkel is removed, it needs more fuel as well
    changed the needle from midway to all the way rich. didn't seem to help too much. i MIGHT be running lean at idle (fixed) but rich up top. ran out of daylight and patience to take the damn slide apart again but want to try the leanest setting too. at low rpms, middle throttle openings are good. at higher rpms or even some midrange it just goes pop pop pop. not necessarily a lean pop but like its stumbling...
    WOT, its the same thing as midrange, except after a few seconds it takes off. thinking maybe it was too fat and it was clearing the gas out....
    ah yes, i want to do a plug reading but its a pain in the ass to pull to be honest and i thought i could do it by feel....
    valves are adjusted, air filter brand new along with oil and filter. once again def need to pull the plug again. i should probalby do a compression test on her soon too. i jus tdon't think its engine b/c i can get the symptoms to move a bit depending on jetting.
    i'd love some help sometime if you'd wanna give a hand. i live on a cul-de-sac with powerlines at the end so testing is easy, just making the changes def go quicker with someone who knows their shit (or at least pretends) and an extra set of hands. there would be beer involved as well for payment! hah
    You wouldn't think jetting would be this hard. i just got done with my vmax and that wasn't bad. however i did have her on a dyno so we'd just run her, then i'd make the changes based on the a/f curve, which did eliminate the guesswork.
    post above.
    yeah, I'll come over...can't guarantee that I'll help, but I can drink beer!
    when were you thinking? unless I get an last minute call-in for work, I have the next 3 days off
    Jan 2010
    cny
    well name your brand and i'll have some cold ones waiting
    ideally, probably tonight, but if not maybe tomorrow night? then i got shit going on until sunday or so. hoping to get this figured out soon otherwise i may start looking into another dirtbike heh
    Jan 2010
    cny
    oh man tried jetting again tonight. its almost popping like its lean but the plug is reading rich. def at my wits end....
    tried 3 different mains and 3 different needle positions.
    hmm...interesting...when you say "popping", do you mean backfiring popping, or a sharp popping noise when it's accelerating?
    and how's the roll off under WOT to higher rpms's?
    Jan 2010
    cny
    sharp popping noise. def not backfiring i don't think.
    needle range is still shitty too. when i first fired it up today it was the best it had been, but still not great.
    plug is reading rich, but the symptoms still sound lean to me. maybe pick up a new plug before i attempt again. you have any spare jets?
    tried with varrying levels of gafers tape over the airbox inlet, to mimick a stock setup with stock jetting and its still similar to before. makes me wonder if there isn't something else going on. couldn't do a compression test as i said, and the decompress lever wasn't adjusting right from what i could tlel, so maybe that is playing a roll. but the low-mid range is just great, which makes me think if it was top end (as far as the engine) it would show at least slightly down there in that throttle/rpm range.
    Oct 2005
    Wrentham MA
    I am at the race track for 10 days :-0
    Graham
    Oct 2005
    Wrentham MA
    check the exhaust flange carefully - where the exhaust pipe seats into the head.... make sure there is a tight fit/change the gasket.... this is a very common problem - air leaks in on the cam overalp and causes all sorts of strange tuning issues.
    Graham
  1. Shane Watts Dirt Wise School @ Wrentham 4/20-21
    Last Post: 05-10-19, 07:46 PM
  2. New MA Rider (Attleboro / Wrentham / Foxboro Area)
    By SMASHINGMACHINE in forum Welcome and Intro
    Last Post: 05-16-15, 01:55 PM
  3. Wrentham trails - is it ok to ride there now?
    By xxaarraa in forum General Bike Related
    Last Post: 12-21-12, 12:45 PM
  4. Wrentham Trails ??
    By zgr in forum Dirty Bastards
    Last Post: 08-15-09, 03:34 PM
  5. Anybody ridden Wrentham lately?
    By slideruleracer in forum Dirty Bastards
    Last Post: 11-15-04, 11:05 PM
