Page 5 of 9 FirstFirst 123456789 LastLast
Results 101 to 125 of 208
Getting set up for ice riding
  1. #101
    Re: Getting set up for ice riding
    What do y'all recommend gear wise? I was pretty much thinking MX gear with an under layer and some snowboarding gear on top. Sound about right?
  2. #102
    Last time I played I wore cold weather underarmor, leathers, MX pants over the leathers, a heavy sweatshirt over the leathers and a long adventuring touring lined motorcycle jacket. This was near or below zero weather at midnight in the middle of a LARGE lake.
    MX/snowboarding combo is good, as long as you don't care if you happen to trash the snowboarding gear...
    i think im gonna pick up one of the Walls jump suits at walmart. its warm and will take a beating.
    the other option is some cheap olympia sports ski/snowboard gear
  5. #105
    someone mentioned to me that i should consider rejetting the carb for the colder weather. is this sound advice and what should i change and how much should i change it?
  6. #106
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Gear wise. I'm going for my Tourmaster Transitions gear. It's heavy Cordura and has CE armour inside. And it's warm.....
    I'm heading to the test pond here in a bit...
  7. #107
    Member improvedfd's Avatar
    New Hartford, CT
    My front tire is hitting my header. Anyone else have this problem? 2014 500 EXC
    Getting set up for ice riding-20131229_134807_zpsqusdvojx-jpg
    Jan 2010
    Farmington, CT
    2-Strokes like to have a bit more fuel with colder temperatures & typically less fuel with warmer temperatures. An ideal measurement of Air Density is with a Longacre Air Density Gauge for a reference point. Air Density affected by Humidity, Temperature & Barometric Pressure. If riding on Ice, I typically go at least 1 main jet bigger than what I ride in the woods. Can also adjust the Mid-range by a needle clip of the needle to richen up slightly & then re-check the air-screw for best, strongest idle with quick acceleration. Watch your exhaust coming out of silencer for color. If too gray, then probably too lean.
    Sep 2010
    Granville, NY
    I hit the little pond at my in laws for a test session.
    The old girl ran pretty good. The tires are hooking up good.
    I am getting a bit of spark knock.... Need to sort that out a bit.
    Damn this thing is fun on the ice...
  10. #110
    Lifer lopycam's Avatar
    Aug 2003
    Cow Hampster
    Quote Originally Posted by improvedfd View Post
    would have never thought the clearance would have been that close......
    2 inch screws?
  12. #112
    New Hartford, CT
    I'm using 1" screws into a liner. just the standard ama legal kold kutters. I'm really pissed about the damage. Doesn't seem like a normal issue
    Increase preload & compression damping so it rides a little higher?
  14. #114
    New Hartford, CT
    Ya, I increased the compression 6 clicks from normal woods riding and it still hit after landing some harder wheelies
    Lower the forks in the clamps?
    Massachusetts
    If anyone is interested I've got a set of dual sided AMA tires for sale, used maybe 4-5 times. $300 for the set. 19 rear and 21 front. You can email me at info@woodcraft-cfm.com if you're interested.
    I've also got a set of studded MX tires for sale for $150....good shape. These are great for woods riding all winter long, we've been doing it for years. Also 19 rear and 21 front.
    Quote Originally Posted by Woodcraft View Post
    19 rear
    Dammit.
    Meh, I've got the screws... just need the tires n the time.
  18. #118
    Massachusetts
    I've been down the road of making them myself.....unfortunately they never work close to as well as the Fredette tires. Best of luck though.... the only way to be even close is to line your tire with another tire and screw right through them both. From personal experience, the ones that go only as deep as the knobs on your tire rip right out after while.
    Massachusetts
    Getting set up for ice riding-dsc_0910-1-jpg
    Getting set up for ice riding-dsc_0909-1-jpg
    For what it's worth ...here are photos of the tires that I have.
    Yeahhhh, I'd love to pick up some dedicated ice tires but it's just more than I"m willing to spend right now.
  21. #121
    Lifer union's Avatar
    Blackstone, MA
    fwiw I have a set of Erics old ice tires. Way better then making them yourself especially if you dont know how to make a proper ice tire.
    James
  22. #122
    New Hartford, CT
    https://www.youtube.com/watch?v=VLh6...e_gdata_player
    I used this method with great success
    Lifer ZX-12R's Avatar
    Candia, NH
    Yikes! I have a 2013 500 EXC so I'll be curious to see what you figure out. Are you on stock springs and do you fall within their weight range? The EXC's have a pretty steep steering angle to make them maneuverable in the woods. I never even considered that the tire could get that close.
  24. #124
    Central MA
    The EXC's also have very soft compression damping, and the WP open cartridge forks blow through the stroke pretty easily - again, for a plush trail ride. Short of dropping the tubes in the clamps as far was you can, dialing in as much spring pre-load as you can, and also dialing in a lot of compression damping - the only other thing you can do is to buy some new clamps with more offset, or a different angle. All of these things will have some impact on the handling, so serious ice racers will be spending some time finding the hot set up.
    New Hartford, CT
    Thanks for the insight, but I'm not looking to get too serious here. I kept the wheelies to a minimum and I don't think I hit at all today.
    Here is a little vid of my fun
    http://www.youtube.com/watch?v=Jk8qs...=youtube_gdata
  1. Riding
    By 06gixgirl in forum Rides & Events
    Last Post: 08-23-11, 11:56 AM
  2. Riding Courses - Group Riding etc. Gauging Interest
    By csmutty in forum General Bike Related
    Last Post: 02-08-11, 09:23 PM
  3. anyone riding out there?
    By xbubbax in forum General Bike Related
    Last Post: 02-22-08, 01:12 PM
  4. Riding the way they should
    By Rice-rocket1 in forum General Bike Related
    Last Post: 09-06-05, 02:07 PM
  5. Riding
    By GMAN226 in forum General Bike Related
    Last Post: 02-24-03, 10:44 PM
