Results 1 to 3 of 3
water pump impeller tightening?
    is there a trick to tightening it?
    I put the impeller back into the bike, put it into gear, squeezed the rear brake the best I could while trying to tighten it...but it kept moving...not sure if it's tight enough
    how do you keep the shaft still while tightening the impeller?
    '97 CR80R - just installed new water pump seal
    Re: water pump impeller tightening?
    Alternator side cove off, breaker bar on flywheel retaining nut?
    Jan 2007
    Rochester MA
    Or use something to jam the gear coming of the crank. They sell a special tool for this, I have a piece of brass that works percect.
  1. Water pump leak
    Last Post: 05-11-13, 08:02 PM
  2. Water Pump blues....
    By Billy in forum Bike Maintenance
    Last Post: 07-07-12, 06:28 PM
  3. WTB: 04-07 GSXR water pump
    By Ray-Ray in forum Wanted
    Last Post: 04-22-11, 02:06 PM
