Page 14 of 28 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 326 to 350 of 696
I'm dumb. Y'all know it. So make me be less dumb. KDX? CRF? KTM?
  1. #326
    Re: I'm dumb. Y'all know it. So make me be less dumb. KDX? CRF? KTM?
    The pipe was pretty tweaked, sitting in the exhaust port it was a good 30 degrees from straight. Bit of tension on the springs. Hey, look, bolts to make removing them easy. Unscrew bolts. Easy.
    Must of gone in a little cross threaded when putting it back in.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    No dice on riding tomorrow for me.
    Smooth move exlax....
    Fuck
  3. #328
    Zip ties and a finger full of rtv. I'm not even kidding here.
    Also wtf is it with you and broken head bolts?!?
    Zip ties melt. Safety wire for the win.
    His hairy little wrists must need a torque calibration.
  6. #331
    Lefty, loosey. Righty, FOR FREEDOM WAAAAAAAAAGH!
    Tomato tomato. Get it done.
    2 hours sleep the night before, really tired, should not of been working on the bike.
    Got the remains out. Thought I had cross threaded it, nope. Bolt threads were flattened off on that and a few other bolts holding the exhaust plate on. Chased the threads and pulled out a ton of gunk. Grease/dirt/old threadlock.
    Reassembling shortly.
    I've discovered that I don't have any M5x.80 bolts in my spares. I'll have to remedy that.
  12. #337
    No listing for what is contained in the kit, grrrr.
    You missed an epic day riding. Weather was spot on. I mean it doesn't get much better than this. And I cleared that god forsaken rock on River Loop.
    14/51 is how this machine is supposed to be geared. 14/49 is not. Although the process of fitting new junk I moved the axle forward almost a cm (rough guess). Pretty significant effect on how the bike handles. Now its even more twitchy and I'm having a hard time getting it to go where I point it.
    The tusk euro bolt kit I linked earlier is probably worth the $30 they ask for it. RockyMtn has it. Fasteners are OE style; same hex & torx head combo thing going on.
    I've got one of the generic bolt kits and love it, use on the dirty bikes, the road racer, etc. That KTM specific one looks slick too...
    If you read the description he even notes he'll do custom kits if you ping him.
    Found the right length/thread/pitch at Tractor Supply. Got a couple different versions of heads/lengths/grade.
    I couldn't find any other bolts of similar size on the bike to swap. Same ones that hold the exhaust plate on, but doesn't appear to be used anywhere else. At least I didn't have to pull the engine completely to get it out, just removed 3 of the 4 engine mounting bolts. As far as the remains of the bolt, it was actually loose enough to back out with a pair of plyers. The threads on that bolt, and a couple others in that area, were all flattened out from previous work. Plus the hole I was trying to thread in was full of shit. Should be good now.
    I'll order up one of those SpecBolt kits one of these days. At this point it appears I'm covered. New jets/needle to make it right for this weather on it's way too, should be here mid-week. It's currently jetted for hot weather. Don't want it running too lean.
    Bummed I didn't get to go, but shit happens. Been a really rough month here at the house with sickness between me twice, the kid twice and my wife once. I really REALLY wanted to go, but was isn't in the right state of mind to get it all ready in the short timeframe I had to work due to lack of sleep and still having a hard time with my lungs. Working Saturdays sucks too.
    At this point I should be good for this upcoming weekend. I'll go solo if nobody else is game. Weather was mint today and I got out on the Wee for a family gathering and to pick up those bolts. First time on two wheels in over two months.
    Hopefully I'll be able to swap the rear wheel bearings this week with the extra time I have.
    Getting time to go through a bike is a lot easier without a kid crawling around.
    Much better. Chamber points INTO the engine, not 30 degrees off.
    If you're anything like me, you'll fix that on the first outing.
    That orange frame sure is pretty.
    Rotella.
    Like fo'reel or just internet jokey?
    I got that shit EVERYWHERE.
    I gave away all my gear case moto stuff with the 125.
    I have no recluse exp, but any 10/30 works in a 2t gearbox.
    RE: Rotella
    Internet seems to be in approval for a Rekluse equipped KTM using Rotella. So be it!
    Just do it.
    Ordered up a 10 pack of 44mm ID 3mm thick Viton o-rings. The exhaust had none. The exhaust plate itself is heavily gouged from the pipe being bent for so long with no gaskets, may not end up sealing even a little. I'll order a new plate if needs be.
    did you (or the seller) not know about the pipe?
    kinda felt like you should've gotten a turn key bike with your budget...unless this was so cheap, that the condition of the pipe was irrelevant
  25. #350
    Try this well before you go replacing that plate.
    But I think you are overthinking this.
  1. Don't be a Dumb-Ass...like me!
    By sandros in forum Vermont Events
    Last Post: 09-22-10, 08:59 PM
  2. is it dumb...
    By newgixxerchic in forum General Bike Related
    Last Post: 05-15-08, 04:43 PM
