Results 1 to 10 of 10
Learning to fly
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    Learning to fly
    Went to Blue Diamond MX park in PA this past weekend. Took the boat-anchor around the track a bit, and even managed to clear the step-up and one of the table-tops. I got pretty comfortable adjusting the bike in the air with the throttle, but I'm still having a hard time stabbing for the brake lever mid-air.
    The question I have is, how do ya'll hit the jumps? Standing up, stiffed legged? Tips? Tricks? Anything I can learn from. I think its time to hit up Crow Hill too and learn from Clinton and Paul.
    Jun 2005
    Learning to fly
    What the?
    Since when is a 520SX a boat anchor?
    Jul 2003
    Bozeman, MT
    Learning to fly
    I'm kidding of course. For a 520, its pretty fricken nimble, even on the tight stuff!
    Jun 2005
    Learning to fly
    Yeah, and there's little need to worry about having enough oomph to clear pretty much anything around here. Braaaaaaaap.
    Waterbury, VT
    Learning to fly
    Hitting the rear brake mid air will bring the front end down pretty quick. Work your way up to it by playing with body position first. If the front end is a little high, move forward. When you are really comfortable with this, stand soft knee'd in the middle of the bike and just tap the rear brake. Work slowly to the point where you can lock the rear wheel. Then - time it so you open the throttle right before you touch down.
    A tabletop works best for practice (the penalty for coming up short isn't as high as a double). If you can - find one with a nice straight run to it and just loop back to take just that jump - don't run the whole track. To get more air - at the base of the jump cut the throttle back, and then open it back up quick. It's the acceleration, not the speed that will give you the height (play with coming in a gear lower and a gear higher to find the sweet spot). The rest will fall into place with experience. Good luck, start small...
    SSearchVT
    Learning to fly
    Jumping
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Learning to fly
    I ride standing obviously, I usually have my legs stiff when I preload, but bend them as the bike rebounds and throughout the jump to the landing.
    a little crazy... 978chris's Avatar
    Haverhill, MA
    Learning to fly
    pretty much what he said, standing up as you approach the face of the jump right at the transition push down with your legs to compress and pogo stick off your suspension as you gas it off the lip
    i want to get a dirt bike again
    2007 GSX-R600
    1997 ZX-9R (sold)
    1979 RD400F Daytona Special (sold - i know, i know)
    Had at one point or another for off-road: KX125, Four-trax 250R, 250 3wheeler, XR250, XR400
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Learning to fly
    Nice, I went to Blue Diamond for a Red Bull visit ages ago, didn't have bike with me thou. Pretty sweet job learning to fly the friendly skies.
    No two jumps are the same. Some you stand up and preload, some you seat bounce, some you just pin it and hold the fuck on. Key is to be relaxed and in the attack postion.
    Don't Be:
    -Stiff
    -'In the backseat' (unless pushing front down for a landing)
    -Locked legged
    Be:
    -Like water
    -Smooth
    -Relaxed
    -In the Command position
    BRAAAP.
    Boston --> San Diego
    Learning to fly
    Hey Alex. Riding with you was always a blast. I've gotten a lot faster since getting my KTM and would love to chase you around the track again.
    As for jumping, what I've learned is momentum plus power are what's needed to clear big obstacles on most tracks. It usually means being able to carry corner speed and accelerate hard from the apex out to the top of the ramp.
    It's strange, but you can have the rolling speed the same as the next guy, but if you're not in the power, you won't fly nearly as far....
  1. Learning from the master
    Last Post: 12-11-16, 11:55 AM
  2. Learning to ride
    By Duffy in forum General Bike Related
    Last Post: 04-26-10, 06:11 AM
  3. learning
    By igneous in forum General Bike Related
    Last Post: 04-25-02, 09:39 PM
